FileFixer
Well-Known Member
I`m thinking to doing some upgrades on my Technics SL-PS770D CD Player but I dont sure is it possible or not? I Also I`m not professional for electronics and some of these things I dont know too much. On schematics I see that some components and connection dont have too much logic and I suppose that some of that components can to be replaced with better components or maybe not.
This is my observation on this schematics what I can to see... Maybe I`m wrong?!
1. From IC803 pin14 signal goes to IC801 and provide clock signal from IC803 to IC801? Why not use same Quartz X801 to provide that frequency signal directly to IC801 but from IC803 (pin 15 or pin16), same place where clock signal goes to IC802?
2. As Difference amp is used 2 pieces of LM833 Op-Amps (IC804, IC805). Any better Op-Amp maybe can be replaced instead of these LM833? Maybe some of OPA, LM or AD Op-Amps?
3. Same thing as on point 2. IC806 Better Op-Amp?
4. Why this??? Low Pass filter on IC891 if we have low pass filter on IC806 and also on previous IC804 and IC805 (caps in parallel connection with resistor on its feedback). Thinking to remove that Low pass filter completely...?!
5. Removuing muting transistors Q803 and Q804?
What is your opinion, sugestions, possibilities on this? Is it some of that modifications possible or not? How much sound can to better?
This is pictures from schematics...
On these links you can to download complete schematics on JPG or PDF formats...
JPG
https://app.box.com/s/h8evl1vg00vh0n3feor8imctf58ma9r6
PDF
https://app.box.com/s/70fh8o4s44ex6co9gsuo7fujhmluf12i
JPG
