Okay, I just bought this from someone and am wondering, does the strobe and power light stay on all the time or should the Stop button power it down?
They stay on when the TT is off.
Isn't the POWER switch on the lower left front corner, and don't you have to slide this switch to the right to turn on the table? I think pressing the stop button during play merely raises the tonearm, returns it to the rest, and stops the platter from turning. I think you still need to slide the power switch to off to completely turn off the power. Although I could be wrong...
When I get home I will check for that power switch in that location.
thanks
Okay everyone thanks for the input. Here it tis. It is the standby position (middle) on the speed slide. Left is 33, right is 45.
I have a SL-QD3 which is the full automatic version of your SL-QD2. The strobe will stay on all the time regardless of platter operation until the speed selector switch is set to the off (middle) position. That will power down the electronics.
