    Dismiss Notice
The downside to multiple pairs of speakers in one room
Discussion in 'General Audio Discussion' started by z-adamson, Dec 31, 2017.
  1. z-adamson
    z-adamson Super Member
    1,657
    How much of a loss is there when you have one pair of speakers playing and 5 pairs of speakers not playing in one room?
    I am talking about large bookshelf, 3 way type of speakers.
  2. Blue Shadow
    Blue Shadow I gotta get me a new title
    21,474
    SE PA
    If they are positioned properly and used as room treatments, bass traps, they can be beneficial. I have 5 pair of larger speakers filling up the corners at the front of the room, behind the main speakers. That is my excuse and I'm sticking with it.
    AlTinkster92 and UncleBingo like this.
  3. asilker
    asilker Bible Reader Subscriber
    2,694
    Chicago IL
    There are threads here about this. people have mentioned that all of the woofers in the room will move as one set is playing
  4. restorer-john
    restorer-john Addicted Member
    6,534
    Australia
    I remember experiencing the phenomenon when setting up the speaker room to a large comparator in my retail days. Each additional speaker pair affected the room acoustics, especially the large floor standers. Basically, they became 'passive-absorbers' (my term for it). Pressure was soaked up by the un-powered speakers moving, especially of course in the bass region.
    My solution is to short the terminals of the unused speakers in my listening room- the bass drivers are then electromagnetically damped and sound improves significantly. Try it out- you'll be surprised. Make a short 4mm jumper lead or use a paper clip.
    Realistically there should be only powered speakers in your room, but for most of us (hoarders/collectors) we have several pairs...waiting for audition of course. :)
    At one point I was messing around with feedback systems and used un-powered speakers, being modulated by nearby speakers as they produce quite a bit of EMF.
    Bill Ferris and bluemooze like this.
  5. motorstereo
    10,519
    Connecticut
    My solution is simple..........if they're not in use turn them around and have them face the wall just like we used to have to do after misbehaving:).
  6. Mister Pig
    Mister Pig Pigamus Maximus Subscriber
    10,488
    Olympia Washington
    My solution is to own one pair of speakers.
    Regards
    Mister Pig
  7. WaynerN
    WaynerN AK Subscriber Subscriber
    5,515
    Minnesota
    I have 9 pairs of speakers in my vinyl room. 4 sets in front, 1 set in lower front, and 4 sets at the sides used a binary type of speakers (which is pretty fun with causal listen to FM (primarily classical). All but one is connected to an amplifier. I really have no interactions between (yes, perhaps woofers do move), but I listen to my speakers at 9 o'clock or less and the fronts are at a different level then the side speakers.
  8. jrtrent
    jrtrent Super Member
    3,391
    Linn used to insist on dealers having what they called single-speaker demonstration rooms, meaning that only the driven pair is in the room when demonstrations were being performed. There has been some debate as to whether or not there is an audible effect. My recommendation is to clear your room of all unused speakers, then test it out by comparing the sound with and without some extra speakers in the room. In other words, let your own ears decide if the extra speakers are a problem.
    "Linn also invented and introduced the concept of single speaker demonstration for hi-fi retailers, as un-driven loudspeakers present in the room re-radiate in sympathy with the driven loudspeakers, distorting the music. Single speaker demonstration was intended to replicate the reality of a person’s home listening environment, and so judgments made in a hi-fi retailer would bear out when products were purchased and taken home."
    https://www.linn.co.uk/company-history
  9. totem
    totem AK Subscriber Subscriber
    5,356
    Vancouver Island
    In my case it was immediately noticeable when I placed a pair of 15" EV's behind my main speakers.
    And not in a benificial way, but to exacerbate the effect they were in the corners.
  10. crazy-in-az
    crazy-in-az All humans are vermin... Subscriber
    2,968
    Kingman, Arizona
    I turn all of my unused speakers so that they face each other woofer-to-woofer. Not only does that keep them from interacting with the speakers that are playing but it protects the drivers from damage.
    MistaChen and motorstereo like this.
  11. the_nines
    the_nines AK Subscriber Subscriber
    19,496
    Montreal
    I never really grasped the concept of more than one pair of speakers in a listening environment (excluding of course surround sound for home theatre).
    If the speaker does what it's supposed to do, all you need is two. If you need more than two, then your present speakers (or system) are lacking something, and/or your room setup is not optimal.
    I'm with the pig on this one.
    stish, Bill Ferris, bobins08 and 2 others like this.
  12. BigElCat
    BigElCat Mmm Hmm Subscriber
    7,893
    South of Kansas City
    Dang guys.
    Now I have to find some place to store my subwoofers, which can't be used with my current set up.
    I touch the cones, and sure enough, they're vibrating with no power going to them.
  13. asilker
    2,694
    Chicago IL
    Other obvious downsides to having multiple speakers include
    - losing tons of usable square footage
    - trading a clean asthetic for something that's visually overwhelming
    - losing acoustic space and introducing weird diffraction points
  14. lini
    lini just me...
    5,901
    Munich, Bavaria
    t_n: Well, for one thing there can be several listening environments in one room, and then one might also have several speakers for a single listening environment, depending on the application. For example, in my "computer corner" I have a pair of smaller nearfield monitor speakers placed closely to the monitor for general use plus a pair of bigger bookshelf speakers a bit farther away for a more room-filling presentation mainly for music listening. Same on the other side (my "TV side", opposite of my sofa/bed) - smaller nearfield monitors next to the TV set, bigger bookshelve speakers a bit farther away.
    Greetings from Munich!
    Manfred / lini
  15. SoCal Sam
    SoCal Sam Lunatic Member
    18,865
    Brilliant marketing. Neat audiophile theory that appeals to the OCD that is overt in some and latent in others...and gets rid of the competition. No chance of the listener hitting that pesky component selector switch and discovering that something else fits their sound preference better.
  16. JoeESP9
    16,621
    Philadelphia PA
    It's an indisputable fact that extra unused speakers in a room have a negative effect. If you must have them you should short the inputs as already mentioned.
    stish, Bill Ferris, totem and 2 others like this.
  17. asilker
    2,694
    Chicago IL
    PRAT PRAT PRAT PRAT PRAT PRAT
    does it have prat? It's gotta have prat!
  18. SoCal Sam
    18,865
    As long as there is a sale to be made...
    asilker likes this.
  19. Rockyhill
    Rockyhill No marigolds in the promised land Subscriber
    3,200
    Maine
    How about two systems each with a connected pair of speakers? In other words, no unused speakers.
    Bodyblue likes this.
  20. Bodyblue
    Bodyblue AK Subscriber Subscriber
    3,500
    CA
    Maybe all you need or want is two speakers, but many find that boring. Many enjoy the sounds of different speakers and systems......but thanks for telling us what we all need.
