1. Welcome to the new server. If you would like to help out with the cost of the new server, check out the thread "Audiokarma's server needs your help" in AK NEWS.
    Dismiss Notice
TIMES ONE amp??? any info
Discussion in 'Solid State' started by kolledog, Sep 6, 2012.
  1. kolledog
    kolledog AK Subscriber Subscriber
    625
    Bethel, CT 06801
    I just picked up a massive, fan cooled, dual mono solid state amp. RCA and XLR. Brought it up on a variac over the course of four hours and it works fine.
    Aside from some French printing on the back (Risque De Choc!!!) there is no info about the amp. It says Times One on the faceplate. Transformers made by Lazara Electronics, LTD. in Montreal, Quebec.
    Any of you audio nuts know anything about this 70 lb. (+-) beast?
    Thanks
  2. Jlord
    Jlord Active Member
    409
    NY
    It.. uh.. certainly looks impressive
  3. ryuuoh
    ryuuoh FFXIV Summoner Subscriber
    9,140
    Marina CA, USA
    Pretty interesting pro amp. I'm guessing it's a Canadian company, the transformer manufacturer has an internet history, but not for Times One. Better pics of the badge and print on the back might help.
    BTW, does it work?
  4. kolledog
    625
    Bethel, CT 06801
    Yes, it is Canadian. There is nothing on the back that gives information about its manufacture, other than some french/English labels, and as I said in the original posting, the amp works fine. Here's more pix
  5. petehall347
    20,982
    uk.. the middle bit
    Risque De Choc=Shock Hazard
  6. kolledog
    625
    Bethel, CT 06801
    Sans blague?
  7. ryuuoh
    9,140
    Marina CA, USA
  8. kolledog
    625
    Bethel, CT 06801
    How's this
  9. theophile
    theophile Pheasant Plucker. Subscriber
    You mean that it isn't about ribald chocolates? :no:
  10. Maurice27
    Maurice27 New Member
    3
    San Francisco Bay Area
    I know a little about it. Times One Instruments was run by a very creative electrical engineer named Brahm Segal. I met him in about 1997 in connection with another (non-audio) business he was starting. He was living in Los Angeles when I met him, and I recall he said he previously lived in Canada.
    He showed me one of the audio amplifiers he was building at the time, which he sold to professional recording studios. They were similarly massive to the one in your photos, but a more modern design and more neatly and elegantly constructed. The front panel was made of a slab of stone, maybe black marble or onyx. Whatever its performance, it was very impressive just to look at.
    I got the impression that Times One was a very small company. I suspect Brahm built the amps himself. I haven't heard of him or his company in many years. You have a collector's item built by a designer-craftsman.
    Maurice.
  11. Maurice27
    3
    Maurice.
  12. theophile
    Wow. An echo, two hours apart. Longest echo I've ever heard of. :scratch2:
    Great first and second post Maurice.
  13. pdm4606
    pdm4606 Super Member
    2,332
    Las Cruces, NM
    times one
    Looks like a dual mono design to me. 2 power supplies and caps.
    How much / channel?
    Paul
  14. Maurice27
    3
  15. Michael F
    Michael F Active Member
    133
    Montreal, Canada
    I`d like to share some experiences with Brahm Segal and that particular amplifier back in the early 1980s.
    Times One was essentially a re-badged Proximity model 500 amp produced in Montreal in the mid to late `70s by Kairon Electronics that rose up from the ashes following Kairons demise. Brahm was indeed the designer of the amp but I`m unsure of what position he held at Kairon.
    I had the misfortune of owning a Times One amp that I used to drive the LF section of a triamped PA system. Rated at 250 and 400 wpc, 8/4 ohms respectively, it sounded decent enough... when it worked. Mine went Supernova in a way a Phase Linear would have been proud of, in the middle of nowhere one night taking out all the cones with it:(
    Traded that POS in for a DC-300a and lived happily ever after. Brahm submitted samples of that amp to the Canadian Broadcasting Corporation for evaluation but they were quickly rejected due to high frequency oscillation issues and a generally poor design. They eventually settled on Bryston, smart move.
    I came across those amps once in a Poughkeepsie NY nightclub powering a bizarre horn loaded speaker system (Conk?) that Brahm Segal was associated with. That experience was uneventful so maybe the design was tweaked.
    If I`m not mistaken, member Anatech has had the pleasure of working on these amps.
  16. luvvinvinyl
    luvvinvinyl Admin Staff Member Admin Subscriber
    24,429
    Windsor, Ontario, Canada
    I just had an interesting discussion with Brahm Segal, about his Times One amps. They were built for a few years, in the late '70s, under his aegis.
    They were reincarnated about a decade or so later, in Brazil, without his participation or guidance, nor any knowledge of this, at all.
    He wondered if any AKer's had any of his amps. I guess the answer would be yes.
    If you have one, he would be interested in reading your posts, in this thread.
    (He was offline, traveling, when I called him, so he asked me to post up for him.)
  17. MrSparks
    MrSparks New Member
    4
    I own two Times One Musician 402RF power amplifiers. Both have issues. I was hoping to find some schematics for them. I fohnd these on the street in NYC in the late 90's
