Walt
Well-Known Member
It occurred to me that most likely it is your swap file being swapped back and forth from RAM to HDD ... if the page file was set inappropriately for the RAM size you have (sometimes even Windows doesn't manage it very well either), then this could cause the apparent thrashing back and forth.
Try this (to manually set your page file sizes) ...
1. Right-click "My Computer" on the desktop and select "Properties"
2. Click the tab "Advanced" and then in the Performance section click "Settings"
3. Click the "Advanced" tab and then in the Virtual memory section click "Change"
4. Click the "Custom size" button and in the two text boxes, enter a number that is 1.5 times the amount of RAM in your system (ie: if you had 128MB of RAM you'd type 192 in both boxes)
5. Click OK and restart your system when prompted.
See if that helps ...
If not we'll try something else.
Also let me know what Task Manager reports is happening to CPU usage and the Page File size when you hear the grinding begin.
