I am not sure if there is another list like this on the forum or for that matter how many more there are, but I thought I would share this one. I stumbled on it while searching for trannies replacements.
First I want to thank Mike from Hudson Valley HI FI for posting this on his site (no affiliations)
2SA489a —> KSB596Y
2SA493 —> KSA992
2SA497 —> KSA1013
2SA606 —> 2N5416
2SA628 —> KSA1013 *watch pin outs
2SA640 —> KSA992
2SA720 —> KSA1013 or KSA1220 *check voltages
2SA722 —> KSA992
2SA725 —> KSA992
2SA726 —> KSA992
2SA733 —> KSA733 or KSA992
2SA763 —> KSA992
2SB507 —> KSA940 or MJE15033G
2SB536 —> KSA940
2SB539 —> MJ21193G
2SC458 —> KSC1845
2SC485 —> KSC1845 / KSC2073
2SC497 —> KSC2383
2SC693 —> KSC1845
2SC732 —> KSC1845
2SC789a —> KSD526Y
2SC793 —> MJ21194G
2SC857 —> KSC2310
2SC869 —> KSC2310
2SC870 —> KSC1845
2SC871 —> KSC1845
2SC905 —> KSD1616
2SC945 —> KSC2383 or KSC945
2SC959 —> 2N3440
2SC984 —> KSC2383
2SC1000 —> KSC1845
2SC1060 -> KSD526 (output drivers)
2SC1124 —> KSC2690
2SC1175A -> KSC1845 (phono section, Marantz 2325)
2SC1212 —> KSC2690
2SC1213 —> KSC2383
2SC1222 —> KSC1845
2SC1312 —> KSC1845
2SC1313 —> KSC1845
2SC1318 —> KSC2690
2SC1328 —> KSC1845
2SC1344 —> KSC1845
2SC1345 —> KSC1845
2SC1364 —> KSC2383
2SC1384 —> KSC2690
2SC1416 —> KSC1845
2SC1451 —> KSC3503
2SC1515 —> KSC2310
2SC1624 —> MJE15030G
2SC1775 —> KSC1845
2SD287 —> MJ21194G
2SD313 —> KSC2073 or MJE15032G
2SD325 —> KSC2073
2SD381 —> KSC2073
2SD669 -> KSC3503 (output coupled thermal regulator in marantz 2245 and 2270)
2SD712 —> KSC2073
Edit 11/15/2015
Ok, so while this topic is not new (transistor replacements), it is still a hot topic since most of us have to replace out of production transistors (and other components for that matter), while rejuvenating or bringing back to life our vintage gear.
I personally had a lot of questions and went through numerous posts to identify components. I have to personally thank Avionic, EW, Ilimzn, Clinic and the other folks who pointed me in the right direction.
Because I did not find an updated list, I would not mind to build upon the list from HV, expand and bring it up to date. I will leave the HV list on top, unaltered. See updated list below!
Because different transistors go out of production as new ones come in, it will be ideal to have a dynamic list, however, this may be difficult to maintain for a longer period. I will try to edit this list until the mods will no longer allow me to do so.
If anyone has any suggestions on how to accomplish this better, please let me know.
Obviously, the more replacement suggestions you post, the more will make it to the list before the list can no longer be edited. I will start by adding some of the trannies I needed to replace. For some I found replacements, for others not.
Please also post questions if you need to replace a transistor for which you did not find a replacement.
Sorry about the formatting. I obviously have this in Excel, but there are limitations on what can be uploaded. I will try to make it available on a shared drive in the future.
Vintage Gear Transistor Replacements
2SA493 → KSA992
2SA497 → KSA1013
2SA564A > KSA992FBU
2SA606 → 2N5416
2SA628 → KSA1013 *watch pin outs
2SA640 → KSA992
2SA720 → KSA1013 or KSA1220 *check voltages
2SA722 → KSA992
2SA725 → KSA992
2SA726 → KSA992
2SA733 → KSA733 or KSA992 ksa733 and ksc945 should be ksc945C and ksa733C. The C moves the collector to the center pin. Without the C the base is at the center pin. It is also important to note that the 2SA733 is rated for 625 mW and the KSA733 is only rated for 250 mW. The KSA1013 is better (900 mW) but its Ft is lower and gain is a little less.
2SA740 → KSA940
2SA763 → KSA992
2SA809 → KSA1220AY
2SA810 → KSA1220AY
2SA858 → ?
2SA909 → 2SB645, MJ21193G
2SA970 → KSA992
2SA1050 —> MJ21193 (PNP)
2SA1051B —> 2SA1943
2SA1301 → 2SA1943, MJL1302, MJL4302
2SA1302 → 2SA1943, MJL1302, MJL4302
2SA1306 → 2SA1837, MJE15033
2SA1309 -> KSA1015 (different package)
2SA1352 → KSA1381
2SA1358 → ? Still available at B+D (but they usually need to be matched. An alternative would be nice)
2SA1115 → ?
2SA1117 —> 2SA1494
2SB507 → KSA940 or MJE15033G
2SB536 → KSA940
2SB539 → J21193G
2SC458 → KSC1815 KSC1815 is the exact replacement.. KSC1845 is a higher voltage replacement.
2SC485 → KSC1845 / KSC2073
2SC497 → KSC2383
2SC555 → MJ15022 or MJ15024 → MJ21193 or MJ21195 (edit 06/22/16)
2SC644 → KSC1845
2SC693 → KSC1845
2SC732 → KSC1845
2SC734 → KSC1845?
2SC789a → KSD526Y
2SC793 → MJ21194G
2SA839 —> MJE15035
2SC857 → KSC2310
2SC869 → KSC2310
2SC870 → KSC1845
2SC871 → KSC1845
2SC905 → KSD1616
2SC945 → KSC2383 or KSC945
2SC959 → 2N3440
2SC984 → KSC2383
2SC1000 → KSC1845
2SC1124 → KSC2690 (watch pin-out)
2SC1166 → ?
2SC1212 → KSC2690
2SC1213 → KSC2383
2SC1222 → KSC1845
2SC1312 → KSC1845
2SC1313 → KSC1815 2SC1313 should better be replaced by KSC1815 rather than KSC1845.
2SC1318 → KSC2690
2SC1328 → KSC1845
2SC1344 → KSC1845
2SC1345 → KSC1845
2SC1364 → KSC2383
2SC1384 → KSC2690
2SC1416 → KSC1845
2SC1448 → KSC2073
2SC1451 → KSC3503, KSC2690AY
2SC1452 → KSC3503, KSC2690AY
2SC1515 → KSC2310
2SC1586 → 2SD665, MJ21194G
2SC1624 → MJE1503G
2SC1775 → KSC1845
2SC1815 → ?
2SC2240 → KSC1845
2SC2460 —> MJ21194 (NPN)
2SC2461B —> 2SC5200
2SC2603 → ?
2SC2608 —> 2SC3858
2SC3280 → 2SC5200, MJL3281, MJL4281
2SC3281 → 2SC5200, MJL3281, MJL4281
2SC3298 → 2SC4793 or MJE15032
2SC3416 → KSC3503
2SC3421 → ? Still available at B+D
2SD287 → MJ21194G
2SD313 → KSC2073 or MJE15032G
2SD325 → KSC2073
2SD381 → KSC2073
2SD610 → MJ15023 or MJ15025 → MJ21194 or MJ21196 (edit 06/22/16)
2SD712 → KSC2073
Edit 08/09/2018:
WARNING: This above list is only meant to be a guideline and not a list of absolute substitutes. Use with caution!
Replacing transistors depends on multiple factors and blindly using these as replacements without additional consideration based on your circuit and individual application, is not recommended.
Below is a very good decision path example provided by @dlucy
Thank you Dlucy and others that have shared your knowledge and added to the list and to this thread!
Link to @dlucy flowchart for choosing a substitute transistor...this case a 2SA726
http://www.audiokarma.org/forums/in...tor-substitutions.688515/page-7#post-11865547
on this page you will find an updated substitute transistors list:
http://audiokarma.org/forums/index.php?threads/transistor-substitutions.688515/page-5
Thank you @dlucy, @Uncle Bambi, @Hipocrates, @ivandezande and all others that have contributed.
2SA489a —> KSB596Y
2SA493 —> KSA992
2SA497 —> KSA1013
2SA606 —> 2N5416
2SA640 —> KSA992
2SA722 —> KSA992
2SA725 —> KSA992
2SA726 —> KSA992
2SA763 —> KSA992
2SB536 —> KSA940
2SB539 —> MJ21193G
2SC458 —> KSC1845
2SC497 —> KSC2383
2SC693 —> KSC1845
2SC732 —> KSC1845
2SC789a —> KSD526Y
2SC793 —> MJ21194G
2SC857 —> KSC2310
2SC869 —> KSC2310
2SC870 —> KSC1845
2SC871 —> KSC1845
2SC905 —> KSD1616
2SC959 —> 2N3440
2SC984 —> KSC2383
2SC1000 —> KSC1845
2SC1124 —> KSC2690
2SC1212 —> KSC2690
2SC1213 —> KSC2383
2SC1222 —> KSC1845
2SC1312 —> KSC1845
2SC1313 —> KSC1845
2SC1318 —> KSC2690
2SC1328 —> KSC1845
2SC1344 —> KSC1845
2SC1345 —> KSC1845
2SC1364 —> KSC2383
2SC1384 —> KSC2690
2SC1416 —> KSC1845
2SC1451 —> KSC3503
2SC1515 —> KSC2310
2SC1775 —> KSC1845
2SD287 —> MJ21194G
2SD325 —> KSC2073
2SD381 —> KSC2073
2SD712 —> KSC2073
Edit 11/15/2015
2SA493 → KSA992
2SA497 → KSA1013
2SA564A > KSA992FBU
2SA606 → 2N5416
2SA640 → KSA992
2SA722 → KSA992
2SA725 → KSA992
2SA726 → KSA992
2SA740 → KSA940
2SA763 → KSA992
2SA809 → KSA1220AY
2SA810 → KSA1220AY
2SA858 → ?
2SA970 → KSA992
2SA1051B —> 2SA1943
2SA1352 → KSA1381
2SA1115 → ?
2SA1117 —> 2SA1494
2SB536 → KSA940
2SB539 → J21193G
2SC497 → KSC2383
2SC644 → KSC1845
2SC693 → KSC1845
2SC732 → KSC1845
2SC734 → KSC1845?
2SC789a → KSD526Y
2SC793 → MJ21194G
2SA839 —> MJE15035
2SC857 → KSC2310
2SC869 → KSC2310
2SC870 → KSC1845
2SC871 → KSC1845
2SC905 → KSD1616
2SC959 → 2N3440
2SC984 → KSC2383
2SC1000 → KSC1845
2SC1166 → ?
2SC1212 → KSC2690
2SC1213 → KSC2383
2SC1222 → KSC1845
2SC1312 → KSC1845
2SC1318 → KSC2690
2SC1328 → KSC1845
2SC1344 → KSC1845
2SC1345 → KSC1845
2SC1364 → KSC2383
2SC1384 → KSC2690
2SC1416 → KSC1845
2SC1448 → KSC2073
2SC1515 → KSC2310
2SC1624 → MJE1503G
2SC1775 → KSC1845
2SC1815 → ?
2SC2240 → KSC1845
2SC2461B —> 2SC5200
2SC2603 → ?
2SC2608 —> 2SC3858
2SC3416 → KSC3503
2SD287 → MJ21194G
2SD325 → KSC2073
2SD381 → KSC2073
2SD712 → KSC2073
Edit 08/09/2018:
