Tung-Sol 6550 Type Three now installed in "Harry Gates" Amp
Discussion in 'Tube Audio' started by kcline, Feb 14, 2018 at 6:47 AM.
  1. kcline
    kcline Tube Audio Collector Subscriber
    1,378
    Triad NC
    DSCN0424.JPG DSCN0425.JPG I have now around 200 HRS on the "Harry Gates Memorial" amp. Have been running a set of Sovtek 6550,s, today changed to Tung-Sol type 3 6550. These are all marked Raytheon Adjusting bias to each tube to 50mA. Hope to listen to this tonight after work. If I cannot tell any difference I will put the Sovtek,s back in. Input tubes are Raytheon Black plate 6201 Driver tubes are 1950's Syl 12AT7,s
    s-petersen likes this.
  2. kcline
    1,378
    Triad NC
    Something I keep forgetting Did any one here know Harry Gates? He lived in Goldsboro NC died about 9 or 10 years ago was well known to radio collectors and was very much into Ham radio, had an all Collins set up
  3. primosounds
    primosounds Single ended KT66/KT88 with 6SL7 or 6SN7 driver Subscriber
    1,825
    Interesting amp. What kind of trannys are used in it? And what is the tube in the middle back for? I am guessing voltage regulation since it doesn't look like a rectifier.
  4. kcline
    1,378
    Triad NC
    The "Harry Gates Memorial" amp has the iron from a ARC Dual 75 amp and has Lundahl input and driver transformers DSCN0329.JPG you can see them at the bottom of the picture. This pic is not the final version that I am using. The 6550 in the back is a Sovtek it is for screen regulation Amp has no caps in audio and no feedback
  5. kcline
    1,378
    Triad NC
    The Tung-Sol's are staying in. Playing the SACD of The Flying Burrito Bros "The Gilded Palace of Sin" the 1st track has the vocals on the outside edge of both speakers, sounds thin and narrow with Sovteks in place. With the TG's sound is fuller wider and more 3d sounding. Hope to play more this weekend.
  6. kcline
    1,378
    Triad NC
    DSCN0428.JPG DSCN0430.JPG DSCN0429.JPG Here are some more pictures of the Harry Gates amp and the Paoli modded Dynaco MK-3. Both these were built by the late Harry Gates, the "Paoli" is not a true Paoli, Harry modded it with the early Triode Board which I have running RCA 12BH7 and Telefunken 12AU7. The finals are Tung-Sol 6550 type 1,s
  7. dcgillespie
    dcgillespie Fisher SA-100 Clone
    9,145
    Ball Ground, GA
    Neat amp! I haven't heard of Harry, but his design certainly looks interesting. Like (apparently) Harry, I wouldn't miss the overly complex front end design of the ARC Dual 75, but at least it looks like he (Harry) did retain the push-pull cathode feedback in the output stage, which is a good thing. Pure pentodes with no feedback at all? Wooof!
    Neat stuff!
    Dave
  8. kcline
    1,378
    Triad NC
    DSCN0786.JPG Here is picture of the Lundahl transformers. This is a before picture as done by Harry Gates
