Vandersteen Model II's
Discussion in 'Speakers' started by ARguy, Apr 5, 2007.
  1. ARguy
    ARguy AR Collector
    1,075
    Wisconsin
    I stumbled into a pair of Vandersteen Model II's and was wondering if anybody out there have a pair and would mind sharing their thoughts on them. Right now they are in my audio storage room waiting to be checked out. I've been on the Vandersteen web site and pulled some info from them but if anyone can shed some more light on the model two's I would appreciate hearing from you. Thanks!:thmbsp:
  2. JimJ[VT]
    JimJ[VT] Super Member
    3,090
    Hillsborough, NC
    The guy I got my ARC preamp from had a pair of 2CE's that I got to hear when I bought it, he was running them off a big BAT amp.
    Listened to some Floyd, some jazz...loved them. Threw a wide soundstage, and even though he didn't have a subwoofer they dug down decently into the bottom octaves. Personally, I would run a small sub but that's a matter of taste.
    Considering what they go for on the used market, they're a steal :D Too bad my amps would pitch a fit with their impedance load and sensitivity.
    cratz2 likes this.
  3. thedelihaus
    thedelihaus Nocturnal transmissions Subscriber
    29,589
    Boston Area, Massachusetts
    The Vandersteen makes it into my top 10 list on what it's merits are.
    Time aligned, wide soundstage, great bass down to 30 hz (although reviews say it's deep bass, they claim it's not "powerful", this due to the purely "relatively" smallish enclosure it's in), quality craftsmenship, warmish sound compared to another delightful speaker, the Thiels. Apartment-friendly, size-wise. bi-ampable. Very revealing.
    Negatives- folks claim the speakers can be power-hungry, and are inefficient. Occasionally the "passive" radiator, which is actually mechanical in nature, and called a sub-bass "Acoustic Coupler", can develop issues. Sometimes the woofer surround separates from the 8" woofer's plastic cone- some have said the plastic cone can develop issues too- but I cannot verify. Kittycats love to shred the cloth covering. Very revealing.
    Here's a good review on them...
    http://www.stereophile.com/floorloudspeakers/914/
    cratz2 likes this.
  4. GordonW
    18,141
    Marietta/Moultrie GA USA
    Original Vandersteen 2s have paper cone woofers, with foam surrounds. If they've never been refoamed, they WILL need it now. Same for the 10" 'active couplers'.
    On some Vandersteen 2 models (2B, 2C, etc), there is also a paper-cone Peerless 4" mid... that will also need to be refoamed. Original first-gen Vandersteen 2s had a dome mid, which is fine unless you blow it up. :D Shouldn't be a problem, IOW...
    So, if the Vandersteens were purchased before 1987, look to be refoaming things...
    Regards,
    Gordon.
  5. BobK101
    BobK101 Active Member
    110
    Pittsburgh
    I have Vandersteen II's, I think they may be C's. There is a C at the end of the serial Number... Anyone know if that indicates they are C's?
    I love them...They are the best speakers I own. I have them Bi-Wired to a Parasound HCA1200, 200wpc @ 8ohms, 300 @ 6 ohms. Very detailed, open, airy sounding. Personally, I wouldnt think of using a sub with them for 2 channel music.
    I opened mine up, checked all the speakers... mids may have a plastic cone... I removed the Active Couplers, as i write this, they are off to Vandersteen for rebuilding. They can go bad, make a strange noise. I think they will be about 80.00 usd each to recondition. Well worth it!
  6. drdetroit55
    drdetroit55 New Member
    28
    Genesee, Michigan
    I have to take issue with some of the "cons" mentioned. I owned a pair of 2ce's which I was relieve of by someone who thoght he needed them more than me. I replaced them with the then current 2ce Signatures (I) and I am using them still. I drive them with a Fisher X202 (1960) integrated amplifier about 18 watts RMS per channel or a Fisher 400 receiver @ 25 watts a channel. I use the 8 ohm tap on both and have no problems. The people complaining about power hungry must be used to horns because that hasn't been my experience at all. My room is 14' X 18' and open to the kitchen which is 14' X 16'. I have no problem filling the space with more volume than my wife is comfortable with. I had a pair of Klipsch Tangent 30's I bought to use with the X202. They worked reasonably well but couldn't compare to the Vandersteens. Admittedly not a fair comparison the Heresy's would be a more valid comparison. But regardless I'm just not a big fan of horns. In the 70's I had Electro-Voice SP15TRX mkII's 15" woofer with a modified T350 horn tweeter mounted coaxially. Electro-Voice sourced the tweeters and midrange horns in most Klipsch products. Never ha a lick of trouble with either of my Vandy's with solid state or vintage tubes, but I highly recommend tubes.
  7. darkblue94
    darkblue94 It wasn't me. Subscriber
    4,324
    Beaverton, Oregon
    You do realize that this thread has been dormant for ten years now, don't you?:)
  8. hjames
    hjames Nabbed ... Subscriber
    9,677
    VA near DC
    I had a couple of JBL based horn speakers and always knew them to be very efficient and not needing a lot of power to play beautifully.
    On the other hand, I have owned 2CIs, 2CEs and 3As and all seemed happier with a good doses of powerful amps.
    I did not play them loud, but they were happiest with +200w/ch amps that had sufficient reserve for occasional peaks.
    The Vandys were nice, but are all sold now - we're currently happier with JBL L212s, Von Schweikert VR-4s, and UREI 809A monitors, the first 2 as options with a 60-85w/ch tube amp.
    cratz2 likes this.
  9. Audiofreak71
    Audiofreak71 Well-Known Member
    555
    I have to agree. It's not that the Vandersteens are power hungry per se on the contrary they can be driven with low watts as long as there quality watts, however the higher the quality watts the better vandersteens will sing, I started with 100wpc and am now up to 300wpc and with each increase in wattage they sounded better.
    Audiofreak71
  10. drdetroit55
    28
    Genesee, Michigan
    So no time like the present to stoke it up again! Peace!
    ranch 22b likes this.
  11. darkblue94
    4,324
    Beaverton, Oregon
    No. There's absolutely no point in doing it. Start a new thread.
  12. bimasta
    bimasta Well-Known Member
    682
    How many of those watts do you use? Are you saying it's having all those watts in reserve that makes the difference? Thanks for the info — I have the Vandersteen 2C.
  13. Audiofreak71
    555
    Yes I'm saying that when listening at lower levels, they have the same slam detail depth imaging whatever you want to call it lol than when I had less power going to them in where listening at lower levels while still sounding good did not behave the same as with more power. I don't know what it is nor why vandersteens sound better with more clean watts but they just do. Maybe if you call Richard Vandersteen and ask him he could give you a better definition as to why, I just know it's better to my ears.
    To add to that, there not the most efficient speakers and do dip down to the 3ohm level so that may have something to do with providing more clean watts adds to them sounding better. I could be wrong but just a thought.
    Audiofreak71
