    Dismiss Notice
What a way to start 2018. The audio goddess smiled on me the 1st day 2018
Discussion in 'Tube Audio' started by sanford12, Jan 1, 2018.
  1. sanford12
    sanford12 Old Stuff New Stuff As long as it's Good Stuff Subscriber
    3,521
    Blue grass country
    Was perusing Craig's list this morning and up pops a very clean looking Eico 2536. Jumped on the phone and he answered on the 2nd ring. Told him I would take it(very reasonable not killer but good). He said he just posted it 5 minutes before. Asked a few questions. He said he'd have it hooked up ready to demo. A hour and a half later I was in his basement and I knew he was a good guy and true to his word the Eico was ready to go. He was a fellow collector and had 2 sets of HPM 100's and 40's. Several vintage Marantz and Pioneer receivers all in a well kept listening room. He had the Eico hooked to a Technics TT and a set of woefully abused Warfendales. Have you ever seen drivers painted with speckle spray paint, so sad. Well not the best test speakers but there was no hum and everything works. The topper is the tubes are all original. 4 made in Holland 6BQ5's, Telefunken ECC85 the rest are Mullards made in Gt. Britian 5 7247, 2 6EU7, 1 5AR4, 1 6AL5, 5 6AU7
  2. gadget73
    36,582
    Southern NJ
    Not an inch to spare on that IF strip.
    Very cool though.
    sanford12 likes this.
  3. sanford12
    3,521
    Blue grass country
    Here's a couple shots of underneath. I like the 2 names written in solder. Whoever put the kit together did a very good job.
    slow_jazz, Retrovert and maxhifi like this.
  4. The Fuxtor
    The Fuxtor AK Subscriber Subscriber
    2,711
    Calgary, Alberta
    those tube shields at the opt's are a nice touch!
  5. crispycircuit
    crispycircuit AK Subscriber Subscriber
    1,416
    near Buffalo NY
    Absolutely Lovely ! Great SCOE......
  6. airtime
    airtime Super Member
    2,160
    Central Arizona
    Wow, you started on the right foot this year. I all but gave up on finding more gear.
  7. drtool
    drtool It might get loud In Houston Subscriber
    2,197
    Houston Texas
    Wow, great factory build you have there.
  8. primosounds
    primosounds SE KT120 w/ 6J5G drivers. Subscriber
    2,644
    Terra, 21st century CE
    Right, i am pretty sure the sheet metal plates separating the tubes from the opt are a custom touch. I have never seen that on an EICO integrated before. Although i have seen it on other amps.
    And a big base 5ar4. that is a very very nice tube.
  9. Alan0354
    Alan0354 Super Member
    2,735
    Bay Area
    I like the metal shield. This will reduce the hum from transformer coupling. For magnetic coupling, you need thicker metal like this to block the magnetic field. I am surprised seldom you see people do this. This works, the thicker the better.
  10. sanford12
    3,521
    Blue grass country
    I looked through a few pictures of 2536's and none had the shields
  11. slow_jazz
    slow_jazz AK Subscriber Subscriber
    13,785
    SE Michigan, Downriver....
    Congrats!!!!!!
  12. Alan0354
    2,735
    Bay Area
    It must be put on by the former owner, good idea.
    Also all the traces are filled with solder!!! I remember I did that also on one of my amp long time ago when I was young. It does not hurt, but not very useful as tube circuits are low current, it's not necessary.
  13. soundmotor
    soundmotor super modified Subscriber
    It's quite possible EICO used a solder bath rather than one-junction-at-a-time soldering. The flux still there looks like points where assembly wires were connected later.
  14. soundmotor
    Definitely cool, well done!
  15. arts
    arts Super Member
    3,615
    Qc, Canada
    Solder coated traces were very common in the early days of solder-bath technology,before masking was developed in order to economize on materials and allow closer trace spacing.Also,trace breakage was an ongoing issue in an era where PCB flexing occurred on a regular basis due to heavier components,heat cycling and the changing of tubes.Many manufacturers specified full solder coat as a reliability practice,and this practice can still be seen long after solder masking was developed. It is still used it to increase current carrying capacity and to aid in component heat dissipation.
    The ''cartridge style'' construction of the IF and multiplex strips put me in mind of the Harman Kardon Citation III tuner.The single tube FM front end module is seen in the products of many different manufacturers,making me wonder if those were an off-the-shelf item.You really need a good,strong tube in this location for acceptable performance.I do find it odd that they would go to the expense of a four-tube IF strip with that minimalist front end though.
    Very nice unit Sanford,and there aren't a lot of them about:) Great start to the new year!
    Art
    drtool and sanford12 like this.
  16. primosounds
    2,644
    The shield is mostly to keep the heat away from the transformers. You would be surprised how effective they are at doing that. Actually, not really necessary since the transformers were designed to tolerate the heat. But, every little bit helps.
  17. primosounds
    2,644
    Also i am not sure if this is a factory build. If i remember correctly, the factory left a "Quality Control by ......." stamp on the top of the chassis with the employee initials who did the final checks or put it together.
    I was in an "eico phase" for several years awhile back and got almost every piece they made.
  18. Leland47
    Leland47 AK Subscriber Subscriber
    2,508
    Nice !!
  19. totem
    totem AK Subscriber Subscriber
    5,344
    Vancouver Island
    The power switch looks original, most including one I had failed and were replaced with toggles.
    Great looking front.
  20. drtool
    2,197
    Houston Texas
    Rivets on the tube sockets = factory.
