What cartridge for my Thorens TD-160?
Discussion in 'Turntables' started by insanescott, Jan 21, 2009.
  1. insanescott
    insanescott New Member
    6
    I have a Thorens TD-160 (I believe an MKI) with the TP-16 MK IV tonearm. The MK IV does not have the removable armwand. I have not purchased a pre-amp as of yet. Can anyone recommend a good cartridge for this model? I've been eyeing the Grado Gold and also the Denon DL-160. I'm looking to spend between $200-$300. Also, I am completely new to turntables and this is my first real table, so if anyone has anything to share please do so, because I still trying to figure everything out. Thanks so much.
    Scott
  2. musichal
    musichal enthusiast Subscriber
    6,914
    Norman OK
    I haven't heard this cartridge myself, but others have recommended the Benz-Micro MC20E2 as a good candidate for a Thorens at about $250. Unfortunately, I'm not quite ready to spend that much myself, but the AKers who recommend it have heard a lot more cartridges than I have, and this would certainly be on my shortlist for that budget. I'm sure they will be along shortly to add to the list.
    You might want to provide a bit more info about ancillary equipment.
    I found this site very helpful in getting my -165 going in good trim. Suggest you check the spring-posts supporting the sub-chassis, as they are sometimes loose. Worth the trouble to retune the suspension if they are.
    http://www.theanalogdept.com/thorens_dept_.htm
    Also, here is a thread about some of my recent experiences with my table, some of which you might find helpful, and includes some cart reco's.
    http://www.audiokarma.org/forums/showthread.php?t=203239
  3. insanescott
    6
    Thanks for the help. As of right now all I have is a cheap $10 pre-amp bought from ebay that will soon be upgraded. I am using this because my Pioneer VSX-515 receiver does not have a phono input. I will have to take a look at the Benz-Micro and consider that as a serious option. Also, I thought I should mention that I will be listening mainly to jazz with my table. Thanks again.
    Scott
  4. whell
    whell AK Subscriber Subscriber
    3,606
    Livonia, MI
    Your choices with the Thorens are pretty wide open. I'd likely avoid the higher compliance cartridges - a Shure V15 for example. Many cartridge prices have generally gone up as of January 1 of this year, so some popular choices that were in the $200 - 300 range are now in the $300 - 400 range.
    You might still be able to find an Audio Technica AT-150MLX in your range, such as this example below:
    http://www.jr.com/audio-technica/pe/AT_AT150MLX/
    It would be on the lower end of the compliance range for your tonearm, but I think it would still make a good match.
    Another option - and one of our good vendors sells this particular cartridge, would be the Ortofon 2M Blue. Look up Fred Longworth on AK and see if he's got any in stock.
    RTOFON 2M BLUE SPECIFICATIONS
    Output voltage at 1000 Hz, 5cm/sec. 5.5 mV
    Channel balance at 1 kHz 1.5 dB
    Channel separation at 1 kHz 25 dB
    Channel separation at 15 kHz 15 dB
    Frequency range 20-25,000 Hz
    Frequency response 20-20,000 Hz + 2 /-1dB
    Tracking ability at 315Hz at recommended tracking force 80 µm
    Compliance, dynamic, lateral 20 µm/mN
    Stylus type Nude Elliptical
    Stylus tip radius r/R 8/18µm
    Tracking force range 1.6 -2.0g (16-20 mN)
    Tracking force, recommended 1.8 g (18 mN)
    Tracking angle 20°
    Internal impedance, DC resistance 1.3 kOhm
    Internal inductance 700 mH
    Recommended load resistance 47 kOhm
    Recommended load capacitance 150-300 pF
    Cartridge colour, body/stylus Black/Blue
    Cartridge weight 7.2 g
    Replacement stylus unit 2M Blue
  5. insanescott
    6
    Thanks so much for the suggestions! I will definitely look into your recommended cartridges.
  6. jmathers
    jmathers Super Member
    1,579
    Royal Oak, Michigan
    Keep in mind the effective mass of the TP16 MKIV is actually less than the regular TP16 arm. The MKIV is 12.5g eff. mass - essentially a medium mass arm. It would be perfect for the AT150 cartridge.
    You might want to check out the Denon 160 and the Denon 110 - a bit cheaper than your range and nice bang for the buck.
    Jeff
