What's the difference between an AR XA and XA-91?
Discussion in 'Turntables' started by Z4N5H1N, Aug 5, 2012.
  1. Z4N5H1N
    Z4N5H1N Nooblet
    80
    Vancouver, Canada
    I've been trying to figure this out for awhile now, but it's hard to find much info. I own an AR XA-91 that my Dad bought brand new in '71ish, and passed along to me. It's awesome, and it's...exactly the same as the AR XAs I've seen online.
    Visually, I can't see any difference between the XA and the XA-91. Does anyone know what the actual difference is?
    Anyone who has more info on the XA-91 in general please post it here too! I'm always curious to learn more about this thing. It's still bone stock, taken out of the box a couple months ago after sitting in storage for nearly 30 years, and it sounds fantastic!
  2. KentTeffeteller
    25,502
    Athens, TN
    XA-91 had slightly upgraded tonearm sleeve bearing. Otherwise, normal AR XA. My XA is also XA-91, mine I bought new in 1973. Excellent basic turntable, the Thorens TD-150 and newer and the Linn LP 12 owe their genesis to the AR Turntable by the way.
    musichal likes this.
  3. beatcomber
    beatcomber AK Member
    17,866
    Lexington, Massachusetts
    I thought the XA-91 was an AR-XA with a Shure M91ED included. I didn't know there were other differences.
  4. grateful
    grateful Super Member
    3,052
    Mass
    bingo
  5. marcmorin
    marcmorin AK Subscriber Subscriber
    9,038
    As mentioned, tonearm post is bigest give-away. The XA 91 will not have the contraption at the top of the arm pivot post to control drop. The arm post is also longer on the XA-91. I believe the XA-91 is the only one with caps soldered into the arm wire tree to get the overall capacitance to what the M91 cart wants to see.
    Peter G and beatcomber like this.
  6. KentTeffeteller
    25,502
    Athens, TN
    Yes, M 91 included as well. Checked my manuals.
  7. beatcomber
    17,866
    So that's why you were asking me if my AR was an XA-91!
  8. marcmorin
    9,038
    Could be :thmbsp: If memory serves me, your pivot post had the small delrin cups (in top shape) that can still be changed out to sapphire ones when you're ready :yes:
  9. beatcomber
    17,866
    I have no idea! :)
  10. Z4N5H1N
    Z4N5H1N Nooblet
    80
    Vancouver, Canada
    Cool, thanks for the info guys. Any thoughts on upgrades for this thing? It's bone stock right now, and it sounds pretty good, but I know these things are popular for modification. I'm thinking a new belt at the very least would be good for it.
    What else can I do to it for not much money that will help it out?
  11. loquatious
    loquatious village elder
    738
    california
    interesting info. i've never seen an XA91. always curious about the variants. my TA is indistinguishable from any of my XA's. never been able to get a grip on why it has a different model designation.
  12. beatcomber
    17,866
    Calling Marc Morin to the rescue! He can hook you up. :yes:
  13. marcmorin
    9,038
    The early days, and what things were called was a bit confusing. The TA I owned was the first model to use 1 motor, and the cast subchassis. The original AR turntable was simply called The Turntable I believe.
    Years later (1983) when AR re-introduced turntables, the middle line model was called The Turntable here in the States, and called the Legend in England.
    Anyway, back to topic. I really know of no difference between a TA and an XA in the years when the XA was single motor, cast subchassis, solid walnut base, with the possible exception that my TA top plate was probably left over enventory of the two motor top plates. Finished in gun metal gray paint instead of the lumpy rubbery crap. Oh and it was in like new condition. Really hated selling it.
  14. loquatious
    738
    california
    my TA is also like new. top plate has the textured surface and its definitely a one motor top plate. i'd been told several times that the TA predated the XA, but studying production serial numbers confirms the models were produced concurrently. my TA came with the original packaging, accessories, and documentation. the AR docs had 1967 dates on them, but as best as i can determine the table dates from 73. also, the box and sticker inside the plinth said "solid walnut" but it was a walnut veneer unit. box serial number and unit serial number matched, so i know it was all original. came with both the regular and "long hair" headshells too. great table, but i do prefer my modded XA to my stock units.
    since there is no difference between my TA and XA's that fall in the same serial number range, i've wondered if the TA's were perhaps units returned for a factory referb. could TA stand for "try again"?
  15. marcmorin
    9,038
    Odd, I didn't know the TA was produced with the later XA finishes such as veneer plywood and the lumpy top. Maybe somebody changed out the base with a later venner version. As the bases aren't numbered like the top plate and base board. I do have several bases that have numbers etched into them......anybody in the market for a SSN? :D <~~<< Really that was a attempt at humor, not a sales pitch.
  16. KentTeffeteller
    25,502
    Athens, TN
    A TA was a 33 1/3 only AR turntable. The first AR turntables were TT models, the XA followed as an improvement. The TA could be converted to an XA by changing the motor pulley to a 2 speed pulley.
  17. loquatious
    738
    california
    my wood base has the original label with the serial number (TA220795) and says "oiled walnut" still glued to the inside of surface of the wood. the packing box has the same serial number and "oiled walnut" stamped on it. mine came originally with a two speed (33/45) pulley. and the original receipt dates it to 1973.
    i was curious about production and compiled some info AR folks might find interesting. it was compiled from ebay auctions over a period of six months in 2011. it documents production changes based on serial number. i cataloged various attributes, but was limited by what could be seen in the auction photos. the info documents that the TA and XA were produced concurrently, and for the same number of years, as you will see, although differentiated by TA or XA prefixes, they both were part of the same serial number sequence, and did not have separate serial number runs. these are arranged sequentially by serial number. its a lot of info. i'll need to split it into multiple posts. first post will document up to the change in base top texture.
    AR turntable production database by serial number.
    XA36261 (ebay, nj)
    motor: double
    base: solid walnut
    headshell: gray
    plinth top: smooth gray
    plinth bottom: gray
    base bottom: slot vents, varnished
    address: thorndike st.
    warranty: 1 year
    XA23408 (ebay, ny)
    motor: single
    base: solid walnut
    headshell: black
    plinth bottom: gray
    warranty: 1 year
    XA38001 (ebay, ma)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    base bottom: slot vents w/hole, varnished
    warranty: 1 year
    XA36924 (ebay, oh)
    motor: double
    base: walnut veneer
    headshell: black
    plinth bottom: gray
    warranty: 1 year
    XA43143 (ebay, oh)
    motor: double
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    warranty: ?
    XA44992 (ebay, pa)
    motor: double
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    t-bar: notched
    warranty: ?
    -----------------------------change to single motor------------------->
    XA46741 (ebay, co)
    motor: single
    base: walnut veneer
    headshell: gray
    plinth bottom: gray
    warranty: ?
    XA49408 (ebay, il )
    motor: single
    base: ?
    headshell: gray
    plinth bottom: gray
    warranty: 1 year
    XA51462 (ebay, mi)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    base bottom: slot vents, waxed
    warranty: ?
    XA55180 (ebay, nj)
    motor: dual
    base: solid walnut
    headshell: gray
    plinth bottom: rust brown
    warranty: ?
    t-bar: notched
    XA55785 (ebay, ca)
    motor: single (converted?)
    base: solid walnut
    headshell: gray
    plinth bottom: rust brown (extra holes/tabs)
    warranty: ?
    XA58379 (ebay, ca)
    motor: double
    base: solid walnut
    headshell: gray
    plinth bottom: ?
    warranty: 1 year
    XA61904 (ebay, ca)
    motor: double
    base: solid walnut
    headshell: ?
    plinth bottom: brown
    warranty: 1 year
    XA64333 (ebay, tn)
    motor: double
    base: solid walnut
    headshell: ?
    base bottom: ?
    warranty: 1 year
    XA72994 (ebay, wi)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    warranty: 1 years
    XA73116 (ebay, ny)
    motor: single
    base: walnut veneer
    headshell: gray
    plinth bottom: gray
    warranty: 1 years
    t-bar: notched
    -------------------------------change in warranty to 3 years------------------>
    XA74801 (ebay, ny)
    motor: single
    base: veneer
    headshell: gray
    plinth bottom: gray
    warranty: 3 years
    XA77449 (ebay, pa)
    motor: single
    base: veneer
    headshell: gray
    plinth bottom: gray
    warranty: 3 years
    XA80174 (ebay, ny)
    motor: single
    base: veneer
    headshell: gray
    plinth bottom: gray
    warranty: 3 years
    XA90250 (ebay, nj)
    motor: single
    base: veneer
    headshell: gray
    plinth bottom: gray
    warranty: 3 years
    XA92873 (ebay, ny)
    motor: single
    base: veneer
    headshell: gray
    plinth bottom: ?
    warranty: 3 years
  18. loquatious
    738
    california
    AR turntable production change database by serial number. part 2 starting with
    -------------------------------change to textured plinth top------------->
    XA95847 (ebay, ny)
    motor: single
    base: solid walnut
    headshell: gray
    plinth top: textured brown
    plinth bottom: ??
    warranty: 3 years
    (nos? blue XB034469 box, XA number altered to 195847, logo on dutcover)
    XA99995 (ebay, ny)
    motor: single
    base: walnut veneer
    headshell: black
    plinth bottom: gray
    t-bar: un-notched
    warranty: 3 years
    (m91ed)
    XA111045 (ebay, va)
    motor: single
    base: walnut veneer
    headshell: black
    plinth bottom: gray
    warranty: 3 years
    XA117441 (ebay, tx)
    motor: single
    base: walnut veneer
    headshell: black
    plinth bottom: gray
    warranty: 3 years
    XA119378 (ebay, ky)
    motor: single
    base: walnut veneer
    headshell: gray
    plinth bottom: ??
    warranty: 3 years
    XA120067 (ebay, ?)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: ??
    warranty: 3 years
    XA121508 (ebay, il) (1969)
    motor: single
    base: walnut veneer
    headshell: gray
    plinth bottom: ??
    warranty: 3 years
    XA126262 (ebay, mi)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    warranty: 3 years
    XA128405 (ebay, xx)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    warranty: ?
    XA129061 (ebay, mn)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    warranty: 3 years
    XA132566 (ebay, il)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    warranty: 3 years
    TA133335 (ebay, ha)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    M91ED
    address: 24 thorndike st. cambridge, mass 02141
    warranty: ?
    TA134128 (ebay, mo)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    warranty: 3 years
    bought 1/30/1970
    XA152492 (ebay, tx)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    warranty: 3 years
    XA152548
    XA160236 (ebay,ny)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    warranty: 3 years
    XA164796 (ebay,de)
    motor: single
    base: walnut veneer
    headshell: gray
    plinth bottom: gray
    warranty: 3 years
    XAU165367 (ebay,can)
    motor: single (universal - adjustable motor)
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    warranty: 3 years
    XAU174219 (ebay,wa)
    motor: single (universal - 2 pulleys)
    base: solid walnut
    headshell: gray
    plinth bottom: ?
    address: thorndike st. (10 american dr on blue box)
    warranty: 3 years
    XA183934 (ebay,va)
    motor: single
    base: walnut veneer
    headshell: black
    plinth bottom: ?
    warranty: 3 years
    XA186551 (ebay,va)
    motor: single
    base: solid walnut
    headshell: black
    plinth bottom: ?
    warranty: 3 years
    XA193199 (ebay, ca) '67 docs.
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    warranty: 3 years
    blue box
    XAU199113 (ebay, co)
    motor: single (universal, 50/60hz)
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    warranty: 3 years
    XA201690 (ebay, az)
    motor: single (universal)
    base: solid walnut
    headshell: gray
    plinth bottom: ??
    base bottom: ?
    warranty: 3 years
    blue box
    XA205105 (ebay, in)
    motor: single
    base: walnut veneer
    headshell: gray
    plinth bottom: ??
    base bottom: ??
    warranty: 3 years
    XA205449 (ebay, or)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: ??
    warranty: 3 years
    XA206109 (ebay, oh)
    motor: single
    base: walnut veneer
    headshell: gray
    plinth bottom: ??
    warranty: 3 years
    XA208008 (ebay, md)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: ??
    warranty: 3 years
    XA210602 (ebay, ma)
    motor: single
    base: walnut veneer
    headshell: gray
    plinth bottom: ??
    warranty: 3 years
    --------------------------------change to solid bottom cover---------------->
    XA211828 (ebay, nj)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: ??
    base bottom: solid, waxed
    warranty: 3 years
    XA214143 (ebay, pa)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: gray
    warranty: 3 years
    XA216141 (ebay, ca)
    motor: single
    base: walnut veneer
    headshell: gray
    plinth bottom: ??
    warranty: 3 years
    TA220795 (ebay, colorado) (1973, '67 ar lit)
    motor: single
    base: walnut veneer (tagged oiled walunt)
    headshell: gray
    plinth top: textured brown (stamped BG)
    plinth bottom: green
    M44ED
    warranty: 3 years
    red box
    XAU239455 (ebay, mi)
    motor: single
    base: solid walnut
    headshell: black
    plinth bottom: ??
    warranty: 3 years
    (international, 2 pulleies and switchable motor. orig sold in germany)
    XA241428 (ebay, ca)
    motor: single
    base: solid walnut
    headshell: gray
    plinth bottom: ??
    warranty: 3 years
    blue box
    XA246789 (ebay, ny)
    motor: single
    base: vinyl veneer
    headshell: black
    plinth bottom: black
    base bottom: ??
    address: ??
    warranty: ??
    t-bar: unnotched
    XA247162 (ebay, wa)
    motor: single
    base: real walnut veneer
    headshell: black
    plinth top: ?? (covered in birch vemeer)
    plinth bottom: ??
    warranty: 3 years
    XA248769 (ebay, az)
    motor: single
    base: vinyl veneer
    headshell: ?
    warranty: 3 years
    ------------------------address change------------------>
    XA249719 (ebay, can)
    motor: single
    headshell: gray
    plinth bottom: gray
    base bottom: solid, varnished
    address: 10 american drive, norwood, mass 02062
    warranty: 3
    XA256272 (ebay, mn)
    motor: single
    base: vinyl veneer
    headshell: gray
    plinth bottom: gray
    base bottom: solid, cardboard
    address: american drive
    warranty: 3
    XA260712 (ebay, ma)
    motor: single
    base: veneer
    headshell: gray
    plinth bottom: ?
    base bottom: solid, masonite
    warranty: 3
    XA264517 (ebay, ml)
    motor: single
    base: veneer
    headshell: gray
    plinth bottom: ?
    warranty: 3
  19. loquatious
    738
    california
    you might be thinking of the TX, which followed the TT. my TA, and every other i have documented had a 33/45 pulley.
  20. KentTeffeteller
    25,502
    Athens, TN
    TX being single speed. Interesting. Some TT and TA were also single speed. My TA was a 3300 ish serial number and single speed only when I got it. I later converted it to 2 speed operation.
