Will the Japanese market Yamaha T-S501 AM/FM work in the U.S.
Discussion in 'Tuners' started by bergun, Oct 10, 2018.
  1. bergun
    bergun Active Member
    433
    Seattle-Tacoma Area
    I have a Yamaha A-S801 Amplifier in silver and looking to add a matching Yamaha T-S501 AM/FM Tuner in silver, but that model is for the Japanese market only.
    With that said, will a Japanese market AM/FM tuner work in the United States? If not, now difficult would it be to have it modified by a professional to work in the United States?
    Thanks for looking!!
  2. Gibsonian
    Gibsonian AK Subscriber Subscriber
    3,732
    Iowa
    Will work fine you will likely need a transformer to run at 100V, that is it.
    Unless the tuner has accommodation for different incoming voltages.
  3. amptramp
    amptramp Active Member
    418
    Mississauga Ontario Canada
    The Japanese FM band is different from the North American FM band. It was 76 - 90 MHz and is now 76 - 95 MHz. It is not the 88 - 108 MHz that we use.
    Aspen and KentTeffeteller like this.
  4. Gibsonian
    3,732
    Iowa
    Well then you're fine then as long as you don't listen above 95!
  5. vwestlife
    vwestlife Well-Known Member
    869
    In addition to the difference in frequency range, the FM de-emphasis in Japan is 50 µS, versus the 75 µS used in North America, so it will sound too bright.
    And also the AM channel spacing is 9 kHz, versus the 10 kHz spacing used in North America, so only some of the AM channels will line up.
  6. bergun
    433
    Seattle-Tacoma Area
    Thanks for the replies... I guess it's basically a lost cause if I go this route since it appears to that this isn't something a professional audio equipment center could/can modify to work properly in the U.S.
    ...Still don't understand why Yamaha doesn't sell their silver faced, "mid-line" AM/FM Tuners and CD Players in the U.S./Canadian markets.
  7. KentTeffeteller
    KentTeffeteller Gimpus Stereophilus! Subscriber
    26,476
    Athens, TN
    Yamaha does not. So, compromise must be made, or go vintage Yamaha from the Silver era.
  8. bergun
    433
    Seattle-Tacoma Area
    Kind of be staying away from used/vintage audio equipment these days... Have a garage full of working and dead units that I've bought over the last 20+ years.
    Plus, I don't have the skills to properly work/fix my own gear... I guess that if I could find somebody to also refinish several metal faceplates in a durable semi-gloss silver finish AND redo most, if not all of the original silk screened factroy markings, that would push me back into the used/vintage market... But, that's not going to happen in my life time.
    I went with a new Yamaha A-S801 since it should be the last amplifier I should need... I also like having the main units to be from the same maker and if possible, the same series... For the most part.
