Experimenting with the microscope, I’ve found you can’t determine the condition of the stylus if it’s viewed from the front, side or back, but if it’s viewed from the tip (looking down), you can see the tracing edges. The reflection from the microscope light shows if the stylus is worn or damaged.
Here are some examples.
GOOD CONDITION TIPS:
This is an elliptical tip. The tracing edge is really a 0.2 mil radius. Both sides are solid and the same size,
The edge of a hyperelliptical tip is a line instead of a dot. Both sides are the same.
Again, the tracing edge of a microridge tip is a line.
The Shibata edge is broader than the microridge.
DAMAGED AND WORN TIPS:
You can see the left side has damage.
This image shows right side has damage.
Uneven wear: the two sides should be the same size.
This image shows damage to both sides.
Of course your ears are the first source in determining damage but a good visual check is viewing from the tip of the stylus since viewing from the front does not reveal any damage to the tracing edge.
