sonavor
Hi,
I have a restored Yamaha C85 preamp as well as a restored C2a preamp. The restorations were mainly replacing the electrolytic capacitors, cleaning switches and resoldering connectors.
Both preamps have been used in my home systems for over a year. Early this year I noticed that when no music was playing there was a very faint but audible hum coming from my speakers. The room had to be dead quiet otherwise I had to put my ear right on the speaker grill to hear the hum...but it was present. I was surprised as I hadn't noticed this before. I rechecked all of the wires that were connect (even changed some). I also played around with grounding the preamp to the power amp (a Yamaha M85). I even swapped in a Yamaha MX1000 as a test. The hum remained.
To further test the problem I listed to another system I had set up which has a Yamaha C2a preamp and a Yamaha MX1000 power amp. When no music is playing I can set the C2a volume wherever I want and there is no sound from the speakers.
So I took the preamplifiers to my bench.
Using a QuantAsylum QA400 Analyzer I could see the difference.
Here is the L & R C85 outputs to the power amplifier when there is no music playing and the volume is turned all the way down. You can see there is the 60Hz line noise at a pretty low level (-95dBV).
-sonavor
-sonavor
