Happened across a dead DC300a, and I'm interested in doing some low cost poking around. When powered on, it instantly blows fuses, and a quick check shows that all of the transistor cases show continuity with the chassis ground. Visual inspection doesn't show anything obvious. I'm guessing that perhaps the insulator on one or more of the output transistors is no longer insulating properly, but I'm early in the investigation. The output and driver transistors are visible in the image below:
From what I've read here and elsewhere:
Output Transistors 3990 = 2N5631 ~ MJ21194G ~ (or 2N3773 with mods noted in the service manual)
Driver Transisitors 5402 = 2N5804 ~ ( I've also seen 2N6306 used)
To get started, I'll need to pull and check the existing transitors and most likely replace them which won't involve much cost, but it will involve some labor. I can't see testing and reinstalling the originals with new insulators as very practical, so sourcing replacements, attempting to match them and finally replacing them will be my first step. I have already removed and tested the big filter caps, and they are in pretty good shape.
I have enjoyed the Tom Waits thread and other DC300 threads, and I know this amp has a varied following with plenty of people in the "boat anchor" camp. I had the original DC300 previously, and I liked it. Also, a winter project for the bench is always a good thing. Any insight on preferred transitor type or sources is appreciated. Also, any insight regarding common failure points or issues that must be addressed on these is appreciated.
