Hello All,
I picked up a Zenith Allegro set that’s super clean with original manuals and everything is in excellent working order with the exception of the turntable not spinning. I’ve cleaned most everything up and motor is spinning freely. The idler wheel is making contact with the motor but will only spin when slight back pressure is placed on the arm. There’s a hole in the middle of that arm and I’m wondering if there should be a spring to hold the wheel to the motor in this hole or some other adjustment that will keep the wheel in contact with the motor. Any help would be greatly appreciated!!
