I had today off so I decided to see if I could make some electrostatic speakers. I'd been thinking of doing so for about a week - just for grins.
I didn't want to spend any money and even less time.
So - I scrounged together a few parts and in about four hours it was done and pumping out the tunes - sounds good, too.
Here's what I used:
A an old 5 1/4" floppy disk (just the magnetic media)
An old CFL power supply (from a broken LCD monitor backlight).
A universal 110V/220V/5V power transformer.
A few disc caps, rectifiers and resistors
Some paper clamps (not paper clips)
Some old metal computer slot covers (like what's probably on the back of your computer to fill up its unused openings)
Some old PC board material I had sitting around (for the two outside stators).
I cut open the floppy disk envelope and sliced a couple of rectangles out of the inside disk to use for the diaphragm. I reasoned that the magnetic oxide coating might make a perfect high resistance, relatively thin, conductor.
Cut a couple matching, but slightly smaller rectangles out of two equal sized PC boards with a Dremel.
Sandwiched the two diaphragm pieces between the two pieces of holed PC boards (copper side in and touching the edges of the two cut up floppy media).
Squeezed the two diaphragms between the two PC boards using paper clamps.
Made the outside stators using four metal computer slot covers - two on each side - one pair under one end set of clamps and the other under the other. The PC slot covers should not touch the opposite set of clamps.
Put together a simple 1/2 wave voltage tripler and attached it to the output of the CFL driver. Then, attached it to the wire I had soldered to the inside of one of the PC boards which was pressing against the floppy disk media. That made my high voltage bias supply for the diaphragm (around 1500 VDC). You can buy those CFL high voltage things for about $4.00 each.
Oh - I also added a 40 Meg resistor to protect the diaphragm in case of arcing - I actually had to buy that from a TV supply place today. That was about an hour of the four hour job.
Added a 3 Ohm, 10 W resistor to the 5V primary of the power transformer (so that the amp has a load about 4 Ohms). Wired the two primaries in series to get a step-up ratio of about 1:50. That was (barely) enough to energize the stators with a 25 W amp (about 500V = 10v x 50).
Put it all together using alligator clipped jumper wires on top of a piece of insulating styrofoam.
Checked the wiring.
Tried out the high voltage supply - check
Tried out the stator supply using a variac - check
Hooked it to a Kenwood 6600 I was working on, turned everything on, cranked up the volume and it made nice noise. The bass was distorting (no surprise there) - so I added a 2 uF cap in series with the input as a cheesy crossover and turned the bass down. Now - it sounded good.
I'm going to try using some static protective bag material next as the diaphragm. I think the static dissipative type (resistivity about 10 to the 12 power) will work best - but the anti-static type would probably be OK, too.
I've also thought about making some from old VCR tape strips.
I've attached some photos of my hi-tech system. Anyone want to buy it?? You can use whatever grill cloth you'd like.
DH
Here's what I used:
Checked the wiring.
DH
- that means the VCR tape. And I'd worry about the stretchy plastic sagging over time.
