RuSsMaN
Pudknocker
I picked up a pair of A100's at a local pawn-o-matic for $10, probably about 2 months ago.
Needless to say, the foam was shot on both woofs. I finally got around to removing the woofs, ready to take them in for a re-foam. I notice one of the woofs cones seemed to move a little TOO much (side to side). Well, didn't take long to figure out the vc was rubbing.
Long story short, I had one woof I could re-foam, and the other, well - it'll make a nice small boat anchor.
I took the good driver into my local shop, and had them spec it out. Turns out, it specs nearly IDENTICAL to the Dayton 295-315 10" woof from Partsexpress.
What the hell, worth a try, right? I ordered 2 of the PE 10's, and got them installed today. WOW. They still have that Boston sound, but the bass is un-real compared to the stock version. I didn't expect what I'm hearing - and from a sealed enclosure at that. I can honestly say they hold their own now, musically, with deep(er), articulate bass.
So for $22 each, give the Dayton 10 a shot. Not only is it a great drop-in replacement, but I'd consider it a substantial upgrade over the stock woof.
On another note, when I removed the Boston 10's, they appeared almost identical to the drivers in my Advent Legacy's. I may have to pull one of the Legacy drivers and see where it specs out.
Cheers,
Russ
Cheers,
Russ
