My DIY automatic record cleaner
JimmyNeutron
I guess if I'm like most people here I had a lot of time on my hands while AK was down. I started on a little project (a prototype really) of an automatic record cleaner. I wanted to see if it was feasable to build it with practically no funds - other than mostly the parts that I had lying around the house and garage. At this point I would have to say that YES!!! It can be done - and very, very effectively. Soon I will build another one with much different cosmetics and a few new motors. But here is my first cleaner. I used an old ice cream maker motor for the platter motor because these ice cream makers have to crush ice and are made very powerful - super high torque. No vacuum or brush will even barely slow this thing down. I also used an old Hoover "quick broom" vacuum for the motor as it is a 10 amp motor, is relatively small, and should provide plenty of suction to lift the dirt off the record. I built the box and mounted the vac motor to one side and the platter motor to the underside of the plinth. The vac pick-up was the leg from an old camera tripod that I had lying around. I made a swivle and mounted it. On the underside of the vac I lined it with the soft part of velcro and made a slit for the vacuum suction. I rigged one of my son's toy cups onto the cut-down vacuum motor and attatched a hose to it and ran it thru the plinth, out the top, and into the suction arm. I added 2 switches, 1 for motor on/off, and 1 for vacuum on/off - both with their own power LED's. The platter was from an old record player and I made a mat out of a cork sheet. I mounted a bolt into the motor to act as the spindle - I needed the threads for the record clamp. The record clamp is a cut down and rounded 2X4 board with a nut mounted on the inside. I put the record on the mat, screw down the clamp, spray the surface with a cleaner, scrub it manually (for now, but by days end I'll have a scrubber mounted on it's own arm). Then I move the vac arm over the record and turn it on for a few seconds as it sucks up all the dirt. The small water that's left is quicly evaporated as it passes inside the hose. This thing works very good.
The cosmetics on this prototype leave a lot to be desired. But soon I will start the "real" record cleaner as I envision it. This was just a test run. I'll have a complete step by step detailed description up on my web site later tonight in case anyone is interested. For now, enjoy the pics.
I disagree. That's one of the best-looking DIY record cleaners I've seen (I'm partial to fleckstone paint).
I will be stoked to see your plans, and your version 2! Can't wait!
"i've ordered devices like that before, wasted a pretty penny - i don't mind telling you. if it really works i'll buy a dozen"
Awesome, just plain awesome.
It looks far better than the Keith Monks Record Cleaning Machine kit I bought from Britain some years back. Didn´t last very long either, and the plans for the box were all F..cked up.
I hope you don´t have any copywright on it. I just copied the pics and your posting to my PC.
I must say your Isabella looks even better. You gotta be careful when she grows up. :D
Jorge
Wow, now that is a nice job man. I was just posting in another thread about my DIY machine, which is basically the vaccuming wand, nothing like this beast, well done.
very nice, I'll be hitting your site (again). Always learn something there. Off to check out 440's work first. You guys are an inspiration!
Finished prototype.
I finished the ARK (Automatic Record Kleaner) tonight. I added a scrubbing brush to scrub into the grooves. I must say that this guy performs very well. I've cleaned about a dozen records so far and played a handful. Ticks and pops are drastically reduced and the records now look very shiny and clean. It's really cool seeing this thing in action - even if it is Version .5. Now I just need suggestions for a good home brewed cleaning fluid. ANy suggestions on what you guys use?
Do tell..... :D Where is the thread?
I used to use the formula with 99% pure isopropyl alcohol, distilled water, and a couple drops of Dawn dishwashing liquid soap, in a gallon of fluid. It worked very well, and I never had any problems with it.
However, for the past 10 years or so I have been using ethanol, in the form of Everclear, a commercial grain alcohol purchased at any liquor store, instead of the IPA. It is probably my imagination, but it seems to work better. I also substituted a surfactant made specifically for records for the Dawn. It is called Genie in a Bottle, but I don't know if it is available any longer. It only takes a couple of drops per gallon, so the bottle I have will last me for many years.
I have cleaned thousands of records with this formula using a Nitty Gritty 3.0 record cleaning machine.
Dick Schneiders
Gee whiz Jimmy, that thing is beautiful! Looking forward to reading the complete description (yes, I admit it, with an eye towards plagarism). That is if you don't mind...
Thanks Fotno. I don't mind at all. I've just finished the project on my web site.
Just be very careful because it is loaded with pictures. If you have dial up, you will probably die an old man before they load. :D
That thing is really nice JIM!
Just curious what is your total cost? I'm interested in building one, that's sweet!
Total cost was less than $50.00. I got the motor (a high torque ice cream/ice crusher motor) for $5.00 at Goodwill. The vacuum was also bought at Goodwill for $5.00 and was cut down to just the motor housing to make it fit in the box. I used an old camera tripod leg for the wands, and the wood was some I had laying around. The rest of the parts were small cost items. Less than $50.00 and a couple of days. It works very, very good.
I went to your site to check it out, very detailed I like it.
I'm pretty handy myself with things like this and I'm going to start collecting the parts
to make one. Probably won't be as neet as yours and I'm sure my parts and design will
probably be quite different but at least seeing yours put's it in the general direction of
what I need to do.
That really is a very nice looking design you have and looks to be something that should
work just as good if not better then any other record cleaner I've seen.
Hopefully I can find me some good parts, I suspect the high torque motor will be the
the thing I need to search for then base my design around that and the vacum.
Thanks for the detailed images and the walk through!
Outstanding !!!! :thmbsp: You're project is an inspiration.I have a lot of MDF left over from my woodworking days.Your cleaner has given me reason to bring the equipment out of mothballs and put these scrap pieces to good use.
UPDATE!!!!!!
Today I added an automatic fluid dispenser to my DIY record cleaner. I used a baby bottle for the fluid resorvior, a 12V car windshield wiper moter as the pump, and some tubing I had around the garage. Flip the pump switch for 2 seconds and just enough fluid is dripped onto the record for a good cleaning. I updated my site with the additional pictures.
