OK, time to get my new G22000 ready for action!
When I got this the other day one channel didn't work. I verified that the power amp was OK by switching the RCA's around so I figured it was likely just a dirty switch (which I'm told are common for these) or some other minor aspect such as a cracked solder joint.
First step - figure out how to open this thing up. Quite simple - just remove a zillion screws on the sides, back and under side.
Once open I sprayed plenty of deoxit on the pots and switches and then some faderlube to keep them working smoothly.
Apparently the cleaning fixed the inoperable channel.
While I was in there I let my OCD recapping disorder take over and I replaced about 2 dozen of the electrolytics that I could reasonably get to (and that I had in stock).
I was surprised to see that the 2 phono boards each had 3 caps on the underside. One was a 1uf electrolytic which I replaced with a film cap and the other was a pair of 47uf caps in series which was the equivalent of a 23.5uf bipolar. I replaced that with a single 22uf Nichicon Muse cap. I also recapped the "Flat Amp" PCB's.
Over on the tone board I replaced a bunch of electrolytics as well. I found the PCB had 2 - 10uf caps in series to simulate a 5uf bipolar. I replaced those with a single bipolar 4.7uf Muse and a jumper.
The 5 PCB's I recapped where plug ins. One of the pins (the easiest one to get to) was soldered in and was easy to remove once I heated up the connection. I didn't touch any of the caps in the tuner section.
One of the bulbs was toasted. This uses an unusual/nonstandard "round" bulb. I replaced that with a 12 volt wedge bulb that I soldered wire leads onto.
Next I cleaned the faceplate with some "Brasso" polish. Normally when I clean a faceplate I first soak in some soapy water in the kitchen sink but this wasn't all that dirty and besides, it wouldn't fit in the sink.
A wipe down of the knobs and switch toggles and back together for the test - sounds great!
And then finally for the hard part - carrying it upstairs to the bedroom, hook it up to my Polk Monitor 7Bs, Pioneer PL-707 TT and Kyocera DA-310cx CDP.
Oh, and bolt the 2 halves together.
Sounding good! Looking great - can't wait for my wife to come home and marvel at our new (back-up) bedroom stereo system.
After a few weeks I'll open up the power amp section for a look-see and to tweak the bias pots.
JimB
JimB
