phidauex
High Technology Hippies
Earlier today I went by a guys house to pickup a handful of broken receivers that he had.
I paid 40$ for:
Kenwood KA-7100 - mmm!
Kenwood KR-710 - hmm.
Project One Mark IVB - ???
Sony STR-DE805G -
Heathkit AR-15 - bleh
JC Penny whatever - blah
None of them were working when I got them.
The first I tackled, and my most favored, was the KA-7100. It had a few minor problems. I ended up replacing the transistor that switches the output relays (thanks for the tip, echowars), and resoldering one of the relay coil leads. Then, oddly, I had to decrease the resistor value feeding the base of the relay transistor, because it wasn't getting enough juice to activate the relay. Bizzare. I went from a 33k to a 3k, and now it works great.
It also needed the standard deoxit and cleanup, though the interior was pretty clean. The exterior is in perfect condition, except for a bit of 'smokers finger' that I had to scrub off. Eww. But, its pristine now!
Oh, I also had to replace the LED, the red one died, so I replaced it with a modern blue one. Cute, huh?
Then (and I hope this isn't a sin..) I patched a set of cut-off interconnects directly to the preamp board to create my own Pre Outs. I'm using the amp as a preamp for my Phase Linear, and it oddly does not include pre-outs and main-ins. I just ran my custom little cables out the side of the case (no cutting necessary, they slide out a little space in the case) after patching directly to the preamp board.
Thanks to Squidward for sending me the service manual, as well, I would have been up the creek without it!
Tommorow I tackle the other amps... The other Kenwood looks decent (though it has a note on the side saying, "Caution, smokes when plugged in", gotta be careful with that one!). The Heathkit and the JC Penny are probably not worth my time to repair, but I'll test them out all the same.
The other big mystery unit is the Project One Mark IVB. It is HUGE and HEAVY. It has a stepped attenuator volume control, and all the switches and knobs feel really smooth and quality. It's got TWO phono preamps, two tape inputs, power meters that go up to 140 wpc (though I'm sure it doesn't actually put that much out), and a solid wood case! Its obviously a high-end unit, but I can't find out anything about it!
Does anyone know anything about these old Project One receivers? Better yet... Does anyone have a service manual for it?
Anyway, it was a good day, especially since I got the Ka-7100 in action! This forum rocks, if it weren't for my searches here, I wouldn't have gotten this far!
peace,
sam
I paid 40$ for:
Sony STR-DE805G -
peace,
sam
