Pioneer Recap cross reference
PL-560 Recap Caps (see post #6)
I have a PL-560 and want to recap it...looked at the PL-630 restoration thread and several of the other recap projects (great work by Mark the Fixer and pustelniakr) but I'm bleeding out the eyeballs trying to figure out the replacement caps for these listed pioneer parts:
CEA101M6.3NP
CKDYF403Z50
CKDYB681K50
CQMA154J50
CQMA104J50
CQMA153J50
CSZAR47K35
CQMA104K50
CEA010M50NP
CQMA563K50
CEA010P50
CSZAR33K35
CSZA100K16
CEA101P35
CEA100P35
CKDYF103Z50
CEA4R7P16
CEA220P16
CQMA332K50
CQMA103J50
CSZAR47M35V
CSZA330M10
CEA471M6.3NP
CCDCH330J50
CCDCH560J50
CQMA562J50
CQSH472J50
CEA100P16
CEA471P50
CEA330P35
CEW4R7P250
PCL031
KCE009
PCL030
PCL018
Need a little more tutorial on deciphering... TIA
Highlander52
Ok, heres what i remember from my recent pioneer recap voyage.
CEA are electrolytic radial caps
CEB are electrolytic axial caps
CEANL are low leakage electrolytic caps
CQSA are styrol caps
CKDYF, CKDYB, & CCDCH are all different ceramic disk types
CQPA & CQMA are different types of film caps i believe
CSZA & CSZAH are tantalum caps
I don't know what the other types you listed are. But i'm sure one of the real experts will be here soon to help.
The manual does you a huge disservice, being that cryptic.
Usually on the receivers I have done, they list the UF value and Voltage.
then there's a page of mine detailing the ELECTROLTYIC cap substitutions for the various types. 1uf plus and some 0.1uf to 1.0 uf caps....
I posted these rules of thumb not so long ago:
<snip>
Cap rules of thumb (nichicon)
I use upw, uhe for general caps including signal coupling in that order depending upon stock "cea"
I use ues, uep & uvp in that order for bipolar depending on stock
I use ukl for low leakage caps (in sensitive areas they reduce the noise floor)"ceanl", "cssa", "csza"
0.1uf to 2 uf I use stacked film where they fit: DFS and ECQ
solid aluminum and tantalum caps get stacked film when possible, or ukl's otherwise. "cssa" "csza"
c?B means it's an axial cap = one lead on each end
c?a = radial = both leads on one end
searching at mouser:
easy..... need a 100uf cap? search on: 100uf UPW
then find your voltage and if stocked / in stock and possibly a size choice. go UP in voltage if your voltage is not available.
voila....
sub uhe, ukl, dfs, ecq etc for upw for the different type...
here's my value guesses, you need to visually verify them before I take any stabs at finding a replacement. garbage in = garbage squared out...
<snip>
CEA101M6.3NP 100uf 6.3v
CKDYF403Z50 ---------- = not electrolytic
CKDYB681K50 ----------
CQMA154J50 ----------
CQMA104J50 ----------
CQMA153J50 ----------
CSZAR47K35 47uf 35v
CQMA104K50 ----------
CEA010M50NP 10uf 50v non-polarized
CQMA563K50 ----------
CEA010P50 10uf 50v
CSZAR33K35 33uf 35v
CSZA100K16 100uf 16v
CEA101P35 100uf 35v
CEA100P35 100uf 35v
CKDYF103Z50 ----------
CEA4R7P16 4.7uf 16v
CEA220P16 220uf 16v
CQMA332K50 ----------
CQMA103J50 ----------
CSZAR47M35V 47uf 35v
CSZA330M10 330uf 10v
CEA471M6.3NP 470 or 4700uf 6.3v non-polarized
CCDCH330J50 ----------
CCDCH560J50 ----------
CQMA562J50 ----------
CQSH472J50 ----------
CEA100P16 100uf 16v
CEA471P50 470uf 50v
CEA330P35 3300uf 35v
CEW4R7P250 4.7uf 250v
PCL031 ----------
KCE009 ----------
PCL030 ----------
PCL018 ----------
<snip>
Thank you...the information provided will be a great help...figured I'd have to visually verify them all but hoping for an easier answer to start. Great job again MTF! I'd already looked at your rules so thanks for the refresh.
Capacitor values
OK, figured out which ones (Electrolytic) need replacement. List is below. Mouser number is after the description, then quantity required.
Name description substitute quantity
Drive Control Assembly PWG-017
c21 CEA101M6.3NP 6.3 volt 100 uF NP 647-UES0J101MPM 1
c31 CEA010M50NP 50 volt 1 uF NP 647-UES1H010MDM 1
c34 CEA010P50 50 volt 1 uF 647-UPW1H010MDD1TD 1
c37 CEA101P35 35 volt 100 uF 85C 647-UPM1J101MPD 1
c38-c40 CEA100P35 35 volt 10 uF 85C 647-UPM1J100MDD 3
Control Assembly PWX-028
c1 CEA4R7P16 16 volt 4.7 uF 647-UMA1C4R7MCD2 1
c2 CEA220P16 16 volt 22 uF 647-UHC1C220MDD 1
c8 CEA471M6.3NP 6.3 volt 470 uF 667-ECE-A0JN471X 1
Oscillator Assembly PWX-022
c6 CEA100P16 16 volt 10 uF 647-UPW1C100MDD 1
Power Supply Assembly
c1 CEA471P50 50 volt 470 uF 647-UKL1H471KHD 1
c2 CEA101P35 35 volt 100 uF 647-UPJ1J101MPD 1
c3 CEA330P35 35 volt 33 uF 647-UPS2A330MPD 1
c5 CEW4R7P250 250 volt 10 uF 140-HTRL250V10-RC 1
c7 PCL031/030 .022 uF 75-715P200V0.022 1
c8 KCE009/PCL018 .033 uF 75-715P600V0.047 1
Total of 16
NP means non-polarized, cost about 8 bucks to complete one turntable.
Thanks again to all who've helped.
