Sriskie
Well-Known Member
A guy I work with picked this up at a thrift store and asked me to have a look at it. I adjusted the bias, checked the DC offset (around 11mv.), and cleaned the pots. The only issues I found were a crackling sound through the speakers when powered off and a bent midrange control shaft. I fell in love and bought it from him for 3 times what he paid for it before attempting these repairs in case something went wrong.
I bent the shaft straight and cleaned the relay. I have since been told to never clean relays, live and learn, I guess. I didn't test it after, I just put it away for a couple of months until I finished getting my recroom home theater set up. I wanted to use it in the same cabinet for a turntable set up with a pair of JBL 4311Bs.
When I finally got it hooked up, sure enough, no sound.:tears: Pulled it back out and opened it up. The 1a fuse in F603 was blown. it blew again when I replaced it. The LED comes on and the relay clicks, bias is still within spec, just nothing at the speaker terminals. I don't know what went wrong but I figured the first step was to replace the relay. Thanks to you guys a new relay was found and I installed it this morning. I used my DBT this time to power it up...it stayed bright so I have a short somewhere. The relay doesn't click now, and the fuse didn't blow, I guess due to the DBT?
I have a sevice manual but only a slight understanding of how to read a schematic. Shorts are usually a result of bad transistors, right? I could start pulling and testing them but if you guys can point me in the right direction, I would really appreciate it.:ntwrthy:
