I received this private message today regarding a post I made here at AudioKarma some time back. Since the answer may be of general interest, I am starting this new thread with my answer. Additional information on modifications to the Kenwood KA-6000 can be found by using the AudioKarma search function; keyword Kenwood6000.Came across your advice about servicing a Kenwood KA 6000, and wondered about the reason for bypassing the capacitors you say are not needed and compromise the low end. Could you explain a bit more?
Coupling capacitors, as used in the Kenwood KA-6000 amplifier, and many others, are placed in the circuit to block DC voltage from getting where it is not needed or wanted. In essence the coupling capacitors block DC and allow AC (the audio signal) to pass from one audio stage to the next. However, in order to pass all the desired audio frequencies, the capacitors must be sized properly. If the capacitor value is too small, the low frequencies will be attenuated and the proper balance between the higher and lower frequencies will be lost. i.e. rolled off low frequencies.
In the Kenwood KA-6000 there are seven coupling capacitors per channel between the input of the tone amp and the output of the high pass 40Hz. filter board. Each and every coupling capacitor will cumulatively contribute to the low frequency roll-off of the audio signal passing through the line level preamplifier stages. While each capacitor contributes to the overall low frequency roll-off, capacitors C131 and C231 contribute more than others.
Capacitors C138 and C238 are located, on the schematic, right after the volume control. When one examines the circuit preceding the volume control one sees that C131 and C231 block any DC voltage from going to the volume control. When one examines the high pass circuit after the volume control one can see that C705 and C706 block any DC voltage from that stage going to the volume control. One can then conclude that C138 and C238 are not needed to block DC voltage where they are used. Circuit simulations show, and circuit measurements prove, that removing C138 and C238 and replacing them with wires will improve the preamplifier flatness by extending the low frequency bandwidth of the preamp section.
Before with C138 and C238:
After with C138 and C238 replaced with jumper wires:
Check your Instruction Manual. Schematics of the Kenwood KA-6000 were included as part of the original Instruction Manual. Service Manuals can be purchased online. I purchased a copy of the service manual at: www.servicemanuals.netAnd do you have a schematic?
KA-6000i
