pmsummer
simul justus et peccator
I picked up a sad pair of JBL Lancer S99s last week that were in pretty rough shape. Paid too much ($100), but it's a long story, and honor was involved.
One grill was missing, and 4 of 16 corners were mushed a little, but the drivers were good. The biggest problem was a roughly one square foot of ruined veneer on one of them. It looks like it sat on a wet towel for a few years. Color bleached out. Veneer blistered away and splintered. But I really bought 'em for the drivers, so what the heck, I thought I'd experiment with veneer refinishing...
Before:
What you see here is after the SECOND step (I forgot to document the original condition). The light area is the discolored veneer, and is just how they looked when I got them. This shot is after I put a diluted Elmer's solution under and around the lifted/splintered veneer. The dark area is where the glue seeped out next to a layer of wax paper I put on top of the damaged area before I put the 50 lbs of smooth granite slab (and the other speaker) on top of the spot. The blistering, peeling veneer was about 1/3 of the bleached area.
I began by applying wood filler into the cracks and small missing areas. After it dried, I then sanded the entire area (using elbow grease AND a small orbital sander) to get the wrinkled veneer as smooth as possible.
Next, I applied some Howard's Restor-A-Finish, followed by more sanding, and some more Howard's.
Mid step:
I next added color to the larger wood-filler areas, and then two coats of tung oil with a 0000 steel wool rub.
The results aren't perfect, but these are going to replace my KLH 23s on top of a bookshelf in my office (after I re-cap them). They'll be grill-less, but out of harm's way.
After:
I didn't try very hard to get the dark bands out, but they do look better now.
Also (don't shoot, you JBL purists), but because the surrounds had ossified, I treated them with Castrol DOT4/5 brake fluid to soften the Lans-alloy surrounds. A teeny little bit got on the cones around the edge, but now I can play them and hear something approaching what thwy were supposed to sound like.
Anyone got a single Lancer 99 grill out there?
So, I've got me some JBLs, and some fun. I'm eager to get new caps into them, but that's probably an April project.
Before:
Mid step:
After:
