willyrover
A couple of years ago I picked up a Pioneer PL-530 in pieces at a garage sale. At the time, I painted it black and got it working.
http://www.audiokarma.org/forums/showthread.php?t=120710
The paint did not hold up too well so this weekend I got around to putting on some veneer. The veneer is oak with a wipe on poly finish. :thmbsp:
Unfortunately, in removing the tone arm, I buggered up the tone arm wires so I had to replace them. Then, while replacing the wires, I buggered up the adapter between the tonearm and the headshell. So I eliminated it and ran the wires directly to the cartridge clips. Makes swapping headshells tricky but it eliminates 2 connection points in the signal path that could go bad. The new wires are thicker but don't seem to be binding anywhere.
After finally getting the mechanism put back and working properly, and fixing a ground problem, it's working perfectly and sounds great!
