Linux -- If I recall correctly, you've been battling this one for a while now.
I think the first approach (which you've likely already done) is to disconnect the global NFB network -- but leave it disconnected. That way, you know you are not dealing with any stability issues related to the feedback network. With the network disconnected, then:
1. Any HF instability must be individual stage or layout related. With the GNFB loop disconnected, there are simply no other possibilities that exist. If the unit still has HF instability in the LTP with the loop broken -- even with well proven tubes such as the 12BH7 installed in that position, then the only real option left is a layout fault. If the tube and feedback network possibilities are eliminated from a design that is otherwise quite conventional and well proven to be stable, then layout must be considered as a prime suspect.
2. If any LF instability issues remain, then the power supply decoupling networks must be suspect. Layout will usually have little effect on low frequency stability issues, but power supply decoupling can surely play a major role.
The goal is to get the amplifier completely stable with the GNFB loop open. If that is not achieved, it will surely not be stable with the loop closed, as that will tend to only aggravate the pre-existing stability issues already in place.
To troubleshoot the long tail pair, remove the output tubes (watching no load power supply voltages as appropriate -- use a variac if necessary) and the input stage tube, and replace the input stage tube with an appropriate resistor (from plate to cathode connections) to bias the LTP to the same operating point as if the input stage tube were actually in place. In this condition, the LTP is totally isolated by itself with no active stages either before or after it. It should now be a relatively simple task to trace down any HF instability that is originating from this stage.
To track down LF instability, the output stage will need to be fully operational. If LF instability is still in play with all tubes installed but the GNFB loop disconnected, then (again) replace the input tube with the same resistor as used to replace it with the HF stability work, and see if the LF instability stabilizes at that point. If so, then the power supply decoupling is suspect between the input and LTP stages.
In this manner you can trace down any instability issues that are basic to the amplifier proper before the loop is connected. With the amplifier stable in an open loop condition, then if any new stability problems crop up with the loop closed, you can deal with them then with the absolute knowledge that they are in fact loop related. Until you create this condition however, you don't really know what you're dealing with.
When you get the point where the amplifier is completely stable open loop, then, if LF issues become present (possibly again) when the loop is closed, then coupling techniques such as Hafler used might come into play, but you won't know that until the amplifier is made absolutely stable before the loop is closed.
I hope this helps. Good luck with it, and keep us posted!
Dave
