jhoyt
Incomprehensible space llama
So, I'm looking at some of my surplus gear, and my Luxman LX-104 catches my eye. The face sucked as recently as a year ago, when the unit actually belonged to a friend. In the meantime, I acquired it, and the face quit sucking. So last night I tore it down, as the previous owner said you had to take it quite a bit apart to access the mechanism. I was hoping to find a worn out belt, but 'twas not to be. These use a gear-driven cam that actuates against a bar secured to the chassis itself. It appeared that a tiny gear had stripped, so there was no fix. Instead, I decided to make it "permasuck"; so I bent a paperclip into proper shape to hold the face in the sucked position. Completely un-doable, and didn't have to damage or tweak anything in the process.
LESSONS I LEARNED:
1. Suckface is very cool, but is nearly impossible to service.
2. Luxmen (or at least this one) are very difficult to service in general. Wire routing is abyssmal at best, criminal at worst.
3. For a high-powered amp, the internal speaker wiring is tiny--maybe 18 gauge.
4. Free is good.
5. It's really fun to say "suckface".
LESSONS I LEARNED:
4. Free is good.
