pathologymd
Hi all,
Some time back a thread discussed the silver mica capacitors inside IF and multiplex transformers occasionally going bad. My MR-67 has exhibited (I believe) symptoms consistent with this, including sudden changes in volume heralded by a soft "thump" and apparent restricted bandwidth when tuning and observing the center tune meter.
I went into the tuner slightly twisting transformer cans and then probing the connections and components with a stiff plastic alignment tool. I had the tuner hooked up to a ST1000A with the tuner output monitored on a scope. All the poking and prodding showed no effect until I reached the detector (T6), when the level jumped back and forth on the scope with poking. I touched up the solder joints and inspected carefully, but to avail. I subbed the preceding tube/cleaned the socket etc to make sure movements weren't being coupled to the tube pins. No change. Took the transformer out (see pix). There is one 33 (assume pF) ceramic cap across the secondary (effectively across the anodes of the two diodes), but I cannot find any other caps inside. The schematic indicates one across the primary and secondary. Terry mentioned they were sandwiched in the base but I don't understand!
I attached a couple of pictures. Outside of replacing the one cap and carefully touching up the internal solder joints I'm not sure what to do next.
I am open to suggestions. After the transformer was out, I tested each component that had been attached and all seemed stable and on value.
Thanks for reading this,
Bill
Bill
