Hi, the subject is speaker popping noises when this amp is used....my unit has been on the shelf for 15-20 years and was recently placed in service again (i am the original owner); there are 2-ground wire termnals in the back of the unit and are presently hooked up via shielded wire from the unit to a metal pipe in the crawl space...speaker popping is going on with all 3-zones of speakers.
If memory serves me right, when i used this unit originally (in the early 70's... sparingly for a few years) the same problem occurred...the ground wires from the unit at that time were attached to a metal pin that was placed in the earth outside the house.
The fuses are operational.
My goal is to resolve the popping noise in the speakers; wiring at both the speaker and amp end are attached cleanly...no wire strands hanging around causing issue. If this problem cant be solved, I am looking for suggestions on a replacement unit...i have 3-separate speaker zones (2-outdoors) and 1-indoors...multiple source input is needed (satellite radio, cd-player, etc....no home theater issues).
Your thoughts are welcome.
Thanks,
Chuck
Thanks,
Chuck
