Stereo now:
I've completed modding the second unit, and it's clear that flattening the response and mitigating the high-frequency excesses of the stock Minimus 7 has allowed what bass they produce to balance the overall response nicely; these are eminently listenable minis now. :thmbsp:
In the course of completing the second one, I learned the following:
1) It's not necessary to remove any but the yellow woofer (+) wire to complete the mod. The other driver connections remain at the stock locations.
2) Nor is it necessary to desolder all of the terminals, so long as the lower hole in each is exposed.
Here's the layout and wiring diagram I made while doing this one:
Notes:
http://audiokarma.org/forums/attachment.php?attachmentid=132322&d=1233206613
http://audiokarma.org/forums/attachment.php?attachmentid=132323&d=1233206613
a) A cable tie secures the 3-Ohm resistor to the stock aircore inductor.
b) A short piece of wire (blue) connects IN (-) to the junction of the 40-Ohm resistor and 4.7 uF capacitor, lower right.
c) All other connections are made using the respective component leads.
d) The large inductor lead and tweeter wires dress neatly through the center of the stock aircore.
e) A #4 solder lug installs on the existing plastic boss, upper right.
f) Drill the rear panel to mount the large inductor between the two bosses on the inside centerline using #4 machine screws from the outside.
g) Double-stick foam tape secures the two caps and bottom two resistors to the stock input terminal plate/cup. Epoxy and other glues are suitable alternates.
