Russellc
Addicted Member
But in most DA designs aren't the LF drivers in parallel? If so, each has the same voltage across it so power input to the LF section is doubled, thus the +3dB increase in (assumed) voltage sensitivity cited.
Thought experiment: Assume I have a speaker that produces 90dB with one watt of input under some set of specified conditions. By what's been offered so far, every doubling of the number of speakers results in +3dB increase in level (not sure if were talking sound power level or sound pressure level here). Now assume I have 1024 identical speakers each capable alone of 90 dB. 1024 is 10 doublings so now I have a system capable of 120dB @1W or taking it the other way 90dB @1mW. This doesn't seem reasonable. Taken to an admittedly absurd limit, an infinite number of speaker would be capable of 90dB with zero power input. What am I missing here?
More than just the voltage. Regardless of the voltage, the woofer only has to use up 1/2 as much of its x-max to belt out the same level than it did with only one. Perhaps someone else can put this more "scientifically" than I.
Russellc
