No, but you're set up to do that, I presume, and will present your findings for this forum's perusal, along with YOUR measurements of Smaller Advents for comparison?No do you have a calibration statement for your measuring microphone documenting on axis and off axis performance?
May we see YOUR results on The Smaller Advent for comparison here, please?For anyone doing a scientific investigation into acoustics the test setup must be calibrated and any irregularities must be nulled. As you can see there are significant differences in results based on test mike polarization. At best you can see the Smaller Advent is pretty darn flat across the whole freqency range.
The 2k "suckout" is a measurement artifact. It is caused by the crossover between the drivers and the directional pick up of the measuring microphone.
Measuring mikes even omnis are not completely omnidirectional.
Yeah, well, AR used that practice during their "Vintage" years and abandoned it soon thereafter, along with their reverberant chamber; it is so patently deceptive that no manufacturer or scientist does it, since it ignores the interaction of the drivers in the system.Actually +- 4db is excellent for a speaker. Especially one that has bass response into the 30 hz range and is so small. It is very flat. The polar pattern of the microphone is significant at the crossover point because the radiator is not a point source at that frequency. The correct way to measure is to measure the individual drivers and splice their curves together.
Originally Posted by John Atkinson in Stereophile
Some aspects of the Smaller Advent's measured performance were positive. For example, it reminded me of the benefits for bass performance of a well-tuned sealed box, compared with the reflex designs that are now ubiquitous. But despite its relatively even balance through the midrange and low treble, the Advent's tweeter is a total underperformer compared with modern designs, and its cabinet is way too resonant.
You apparently did not play the AudioMojo game -- all of the contestants measure better than these Smaller Advents.
The response difference is negligible. Overall power response is also a big part of the sound. I doubt a directional waveguide could match the original sound and reproduce the concert hall balance of the original. The woofer and cabinet are a system and are traditionally measured together. The tweeter is measured separately because interference effects between the cabinet and driver invalidates the measurements. They have no audible consequences
