I got it close with 2414H using a series notch, but not so good as with the JBL filter, which I was able to tweak within +/- 1.5 dB. You can vary the attenuation up and down a bit by changing the 0.68 uF within the range of 0.47 - 1.0 uF....Right now I'm listening to the JBL 6"/ Kef B110/ AR3sub 3-way rig using the stock Ewave low sensitivity crossover. There's nothing obviously wrong with this combination and The Trinity Sessions is sounding wonderful as usual. After I work out the mic cable deal I'll measure and fiddle some more. It would be great if the compensation and crossover of the stock crossover works for these.
