#16
This is how the over rating of japanese TT's in general started.
Some years ago: "Hey I found a Technics SP-10 for $25 and a SL-1200 for $20. Isn't that $5 cheaper than it should be? By the way, the SL-1200 has been modified with another bearing, a different platter, another arm base and another arm, it's been made into suspended and belt driven and build into a proper plinth, the motor has been replaced with one of the better english ones and the feet have been modified too, all of it just like suggested by the BBC. Will that make it worth more.?" Maybe we will soon see people paying $2500 for those JVC with or without the same kind of modifications. ![]() "dolph"
__________________
"niklasthedolphin" Denmark. R2R&TT from ‘65. Cass. from ’70. Matching gear in +40 years brought high grade of synergy with class A tube power amps! |
#17
There's something rotten in Denmark.
__________________
What you got back home, little sister, to play your fuzzy warbles on? I bet you got, say, pitiful, portable picnic players. Come with uncle and hear all proper! Hear angels' trumpets and devils' trombones. You are invited! |
#18
#19
I have the JVC QL-Y5F TT from 1980, but I´m not satisfied with it. It playes with a lot of s-sounds on the highs, and I can´t seem to find a PU that works on it, I have tried Ortofon VMS 20 E MKII, Clearaudio Aurum Wood, and nothing, still it makes s-sounds.
__________________
Sansui all the way....! AU/TU-919, AX-7, SE-9, TU-517, SC-1110. AU-417.XP-99 SP-L700 1. Gen. Cdlover |
#20
__________________
Growing up leads to growing old and then to dying, And dying to me dont sound like all that much fun... -John Mellencamp |
| Audiokarma |
#21
Before the Quotation underneath, Horatio said:
"Let’s do it. What will all this lead to?" (Original: "Have after. To what issue will this come?") And then Marcellus say: After Marcellus said that, this is to follow: Q from Horatio: "[Marcellus,*] Heaven will guide its course." (Originally: "Heaven will direct it.") Then Marcellus say: "No, let's follow him." (Originally: "Nay, let's follow him.") [To whom it is directed*] And then they decided to follow the Danish Prince. ![]() "dolph"
__________________
"niklasthedolphin" Denmark. R2R&TT from ‘65. Cass. from ’70. Matching gear in +40 years brought high grade of synergy with class A tube power amps! Last edited by niklasthedol; 11-07-2009 at 09:40 AM. |
#22
Nice turntable!
__________________
#23
I use one of these for my needledrops. Got it from a neighbors yard sale with a Luxman int + tuner also not US models.
http://page11.auctions.yahoo.co.jp/jp/auction/n76253951 Carl |
#24
I've got a QL-Y55F, using it as my thrash table. Meaning the table is mint I just have a AT-160ml cart on it I can afford to play my less than perfect records on. This deck deserves a way better cart, but is perfect with the auto return for recording my record. I don't need to be there when the record ends to cue the needle.
#25
Quote:
![]() Brilliant satire! I've recently been reading some threads on other boards where people talk just about this way, and are serious about it ...and on other boards, where they rip those attitudes to shreds. Even one board where BRITISH people, of the formerly brainwashed variety, have now taken to organizing face-off comparisons in which their Japanese DD TTs (and in one or two cases, idler-wheel drives) have been trouncing the famous suspended designs, leading them to decry the fact that they were "sold a bunch of goods" and hoodwinked for so many years. It has been very amusing to read, as an outsider!
__________________
This space has been reserved... |
| Audiokarma |
#26
Quote:
__________________
#27
Quote:
1 make sure your records are clean 2 make sure the cart. is mounted properly. 3 some records were not made well also and have that SSSSSSSSSS SOUND no matter what you do. 4 used records if the person before you played them on a ceramic cart. that will also cause the sound. |
#28
Quote:
![]() Jimmy
__________________
Current System:Cambridge Audio 640 Azur v2/NAD pp-2/,Oppo DV-970HD dvd/cd/,Luxman T-12 Tuner,Technics SL-1200 Mk5/Grado Red,ADS L810. |
#29
Quote:
__________________
#30
Quote:
| Audiokarma |
| Thread Tools | |
| Display Modes | |
