Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Pioneer Audio
We appreciate your help
in keeping this site going.
FORUM RULES
Reply
Thread Tools Display Modes
  #1
Old 11-06-2009, 01:33 PM
NealinNevada's Avatar
NealinNevada NealinNevada is offline
Floozies in the lobby...
Temperature and crowded equipment problem
Moderators: Feel free to move to DIY, if that is the best place for it...
Yesterday, out of curiosity I took some temperature readings around my receiver (SX-D7000) and my DVR-7000 in my kitchen. What prompted my recording the temperature between the two units was the small distance the DVR-7000's feet placed it above the venting on the SX-D7000 (about 1/4" - I have no evidence that this is too small a distance, probably isn't, but it bothered me). Here is a picture of the setup when I first took a temperature reading (six inches forward of the back of the case on the left side of the case - radio on and fully warmed up running volume at 9 o'clock):
Here is the temperature reading:
Then I took some 2" OD schedule 40 PVC pipe and cut 1.5" spacers (then painted them silver to match the units):
Finally I retook the temperature reading:
As soon as I find some 2" long sheet metal screws I am going to move the feet to the bottom of the spacers. So, maybe about 9 degrees F cooler running isn't important ...I don't know. Can't hurt though .
__________________
Neal
I spend most of my pay on stereo gear, women and beer...I just waste the rest .
  #2
Old 11-06-2009, 10:13 PM
markthefixer's Avatar
markthefixer markthefixer is offline
Tooluser
Good move, while the outside temperature didn't drop much, the interior temperature changes will be greater, and the difference is significant in the long term.
Your solution is more photogenic than my plywood "h" 's painted black.
Remember air has to get IN, before it gets OUT...
EDIT: OH, and look at the back of the DVR, I'll bet it has a fan....
__________________
Nothing is ever completely fool proof, because fools are so ingenious.
  #3
Old 11-06-2009, 10:23 PM
AngelRa's Avatar
AngelRa AngelRa is offline
AK Member
Do the same under the receiver and you may drop another 8 degrees.
  #4
Old 11-07-2009, 03:42 AM
hennessy hennessy is offline
AK Member
I keep computer case fans on top of the amplifier. 120 mm or a couple hard drive cooling units with double small fans and Zalman Fan Mate 2 to control speed and noise. Sure, it does not help the aesthetics (fans are black, and my pioneers are all black) but saves some natural gas for house heating.
__________________
Pioneer Main: PD-65, F-91, 2 x GR777, CT-42, A-88X. Supported by: DV-59AVi, PD-7500, F-449, A-331, EX-9000, SR-60, SP-99D, SP-700D, DT-555, CU-VSX158
  #5
Old 11-07-2009, 08:39 AM
cityslicker's Avatar
cityslicker cityslicker is offline
AK Member
I use a fan on all my gear. If it runs cooler, it lasts longer. Best buy sells cooling fans which are 4" square and 2" tall, and you can't hear them running. I think their about 15-$20. I always run across fans here and there, but they usually make too much noise. I broke down and went to best buy.
Audiokarma
  #6
Old 11-07-2009, 09:31 AM
Quote:
I knew I had to have another experiment for today...as soon as the sun is up I'll be out in the barn making new feet for the receiver.
__________________
Neal
  #7
Old 11-07-2009, 11:03 AM
Mark W.'s Avatar
Mark W. Mark W. is offline
Instantly addicted
WOW your amp makes a lot of heat I have a remote temp probe above and just to the rear of the vents on my amp (my system is in a 5 foot tall completely built in to the wall rack) and unless the room temp is ovr 75 degrees my amp never gets over 74 degree. I have a single 120mm computer fan at the top of the pocket that pulls room air in at the bottom of the rack and exit's out the back side into the shop behind the pocket.
__________________
  #8
Old 11-07-2009, 12:17 PM
Quote:
Originally Posted by Mark W. View Post
WOW your amp makes a lot of heat...
Yes, there are so many variables that can 't be controlled I didn't even bother to mention ambient room temperature, proximity to wood stove, etc. etc.
EDIT: I finished the "feet extenders" for the receiver about an hour ago and installed them. Same conditions (+/-) and now the temperature reads 85.8 degrees F! The original feet extenders and the four I just installed are all 1.5" tall.
__________________
Neal
  #9
Old 11-07-2009, 10:14 PM
cbrworm cbrworm is offline
AK Member
85 degrees is great. I have a modern large Onkyo HT receiver that runs hot. I cut out huge holes in the shelf below it under the openings in the chassis for air and have 2 120mm quiet fans on top pulling air out. The receiver reports its heatsink temps to be 55c and 56c after idling for a while. The heatsinks you can touch with your fingers for a few seconds before pulling away, the video processing chips run much hotter - you touch them it leaves a flat spot on your finger. The receiver has two internal fans that are both 3 speed that blow directly on the heatsinks. The fans don't start until the sinks hit 70c, middle speed starts at 80c. They don't go to high speed until temp is over 80c and high current is being drawn. Once the temp goes over 85c the rail voltages drop from +-65 to +-45, then if it doesn't cool it drops to +-25.
Clearly they designed it to run hot, but cooler has got to be better right? With my additional holes and fans, the thing is still hotter than 130F.
__________________
DD:SX-1250,GX-270D-SS,Sony TC-K850ES,Onkyo DX-C206,Numark TT,GFA-555ii,HTPC,DEQ2496,RSIIIa
HT:Onkyo TX-SR805,ZA SR71,DIYMA12,HTPC
OOS:SX-1010, SX-1050, GX-270D-SS(#2), GX-280D-SS, GX-255,Technics SL-1800, Nak CD-6,INF QLS5,RS4001, Beta20, Seas LOKI
  #10
Old 11-07-2009, 10:23 PM
Mark W.'s Avatar
Instantly addicted
here is what my rack looks like
And with just a little air moving up the rack I haven't had any trouble with the heat.
Not saying you aren't just commenting on how different then my experiance yours is.
My office system is also well packed and I have had no trouble with it (same amp and tuner stack.
In my system far ans away the tuner and it's light bulbs makes the most heat
__________________
Audiokarma
  #11
KingBubba's Avatar
KingBubba KingBubba is offline
"Too Much Stuff"
A lot of times the amp/receiver is placed at the bottom of the stack due to size or aesthetics. Under all but the most problematic situations, I try to always place the amp/receiver at the top of the stack or in a place separated from the other devices. This is not always possible and in that case your inventive idea for feet is now on my to do list. I also have some wood "H's" for separation and airflow, but they ain't too pretty. Thanks for a good idea.
__________________
Sansui G6000,7070
Pioneer SX1250,SX1280
Kenwood KR-8010
Onkyo TX8500II
Pioneer CTF950,Akai GX-S80
DCM TF-600,TF-400 CX-17+ KL Quartets
  #12
Old 11-08-2009, 12:31 AM
aussiedan's Avatar
aussiedan aussiedan is offline
Ambition beyond ability
I have an old Pioneer tube amp in my rack.
My digital thermometer cuts out at 50c/120f.
It runs at about 55c on the outside of the case, according to an old mercury thermometer.
I tried it near the top of the rack, but due to my set up, this put it right under the turntable. The platter became so hot, I wasnt game to put a record on it, even with a shelf seperating them, so back down to the middle.
You could warm your dinner on it ()
All the other stuff above it works ok, but I do wonder about longevity.
__________________
Pioneer:PL-A45D, SM-G204, SA-5300, SA5500II, SX-434, CT-F6161, PD-F505, TX-520, DS switcher.
Technics RS-X980, Kenwood RA-56, Some Akai stuff.
  #13
Old 11-09-2009, 01:41 AM
AngelRa's Avatar
AK Member
I suspected raising he receiver will help, but wow, you got 10F reduction! I am going to do the same to my very hot pre-amp.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
AudioClassics
Grant Fidelity
Turntable Depot
DIY Hi Fi Supply
Audio Doctor
Simply Speakers
Afforable$
DeWick Repairs
Audio Art Cable
Parts Connexion
Audio Atlanta
Audience-AV.com
Sound Stage Direct
Vintage Electronics Repair
FM DX Antenna
McIntosh Cabinets
Zebra Cables
Radio X
Venus HI-FI
MCM Electronics
Politicalchat.org
Videokarma.org
