fixed_term
My beloverd SA-9800 'popping'
Hi guys. I would firstly like to commend everybody on what absolute gold mine of info this place is, especially on old Pioneers. So inspiring was it all that it motivated me pull out and fire up my old SA-9800 that my father had purchased form an op-shop ten years ago for the pricey sum of $110Au.
Now on to the amp's issue. It has the dreaded 'popping' sound in the left channel which only very occasionally sends the amp in to protection mode (usually when cold). After applying Deoxit to all of the switches suggested here it still was popping. I've narrowed it down somewhat to the power amp stage using the preouts on my current Pioneer AVR. I can also recreate the symptom by tapping or blowing air onto the left amp board (pictured). The speaker selector is quite loose, it looks as though it's just the bolt under the fascia. However taping the loose selector also makes it 'pop'. It also looks to have been worked on at some point in it's life albeit rather poorly. Note the slightly melted cables and capacitor added to the wrong side of the pcb in the second picture.
So I guess my question is, where do I go from here? I have basic soldering skills and have downloaded the service manual (US version. Couldn't find a 240v one) but am not confident following schematics.
Thanks in advance
Cal
Thanks in advance
Cal
