KingBubba
"Too Much Stuff"
I am returning now to repair and recap my old favorite, the SA 9500II that I started to fix a while back and accidentally blew the outputs and some other unknown things yet to be found, when I was trying to set the bias. A couple of years have gone by and I have had more time inside some Onkyos, Pioneers and other units and I feel more confident that I will be able to accomplish this task, My thanks go out to Avionic, Markthefixer, Echowars and the others who helped and contributed to this attached thread: http://www.audiokarma.org/forums/showthread.php?t=108465 , Which was phase I of this project. I now settle in to phase II. I wish for it to go better.
My first question gets directed specifically to Markthefixer regarding the output transistors that I will use for this project. I already have the OnSemi MJE15032/33 purchased and the little brackets and jumpers to the heat sinks ready to go. I did all that two years ago. I do, however remember a more recent thread that mentioned a replacement transistor that was more robust than the 32/33s. Mark, if you remember that discussion, what was that transistor and would it be worth it for me to purchase them, even though I already have the 32/33s ready to go? I only would do so if there was a solid technical reason to do so. If the ones I have now will do the job, then I will stick with them.
Tonight I will do a total cap count, from all the boards, and inventory and prepare my order. Since I have this unit already totally disassembled, I plan to do all the things that need to be done. Can anyone tell me if there are some other things that should be replaced, like the tantalum caps in an SX 1250 or the "Flying Saucers" in the Sansui Model 8, that I would not normally know about. I am open to all suggestions and hints. I especially would be glad to hear from those of you that have done the 9500II before. I will try to post as I go and add photos of what I have done.
If those of you that read or remember the thread I have attached here, and have any suggestions of where I should be looking on the driver boards for problems, hints are welcomed. If I should be looking on the PS board, please let me know because I am assuming it is alright and not the reason the relay is not engaging. The power on light was engaging when I last turned this on. Also, would replacing the relay, or its accompanying transistors or resistors, as a matter of course, be a good idea?
Thanks again for any assistance rendered. It is important to me that I accomplish this, but I readily admit that I will be needing help.
