skywave-rider
Slumming in Akihabara
:scratch2:
Do you mean in the order of play? early/late? Please say more.
I was not referring to psychological factors...but you have a real good point.
Acoustical memory is ... shabby. But unless measurements are taken with long periods for evaluation (ain't gonna happen,) showmanship might be important in the fight.
I was referring to placement within the room. I assume the demo rooms are nothing special, acoustically.
Wayne tells me that his systems work well in most rooms because he's using multiple subs at demos like this (Lone Star Audio Fest. is one example, I believe.)
http://audioroundtable.com/forum/index.php?t=msg&th=12482&start=0&
The multiple sub approach documented ad infinitum, smooths the LF response.
I would say also, don't deny the toe-in. I find many audiophiles, I assume because of response characteristics of some dome tweeters --- maybe, point the speakers out parallel from the back wall. That will increase early reflections from the side walls. But bwaslo's home setup has no such issue. I'm saying he should set up the speakers as he would and not let anyone else do it.
We know what we're doin'.
