Let's mod a PL-41 !
Update on PL-41 Group Purchase
I've got prices from several local machine shops and a couple of online ones. With one exception, they all wanted $10-12 apiece as these bearing pads have to be individually machined from Delrin rod stock. My best price by far is from a local machine shop with a quote of $6 apiece for 12, or $4.50 for 20. I tentatively ordered 12 today for pickup Monday at lunch. I'm thinking of extending it to $20 as the total price only goes up $18 and the unit price will drop by $1.50.
I disassembled my spindle bearing (extremely easy, just popping the TT base off (after removing headshell, mat and platter) and unscrewing the spindle bearing cap. It takes all of two minutes from the time you disconnect your TT from your amp. Mine had the busted up plastic thrust pad (see attached picture) along with one thin metal disk under it. They measured 0.083 and 0.017 respectively, for a total of exactly 0.100" in thickness.
Accordingly, I'm having the shop machine the disks to a 0.10" inch thickness and will be leaving out the additional metal disk (although you could leave it in if you wanted and adjust VTA to the extend necessary). I've read in the link I provided earlier that if you put the metal disk under the Delrin thrust pad (in an oil bath), that the thrust pad spins (it shouldn't). Apparently Delrin slicker than whatever cheap plastic was used for the pad in 1969.
I have the following interest so far in the thrust pads:
Naptown Rob - 3
Tromatic - 1
TJLitt - 1
Mark Walters -1
Isotronic -2
midfiguy -1
Please let me know if you want more than the listed number and I'll pick up twenty instead of twelve. Whatever cost I pick them up for will be passed on to you gents, along with $1 for sales tax (the shop's, not mine) and postage combined.
Anybody else reading this, contact me via PM if you're interested in a thrust bearing pad for your PL-41 (or PL-50) or any other TT than needs a 7/8" OD X .10 thickness Delrin thrust pad.
And pbinpb57 is in for two more. It looks like we may be on target for 20 and a reduced price.
BTW, pbinpb5 provided me with an eBay link in which a guy has fabricated stainless steel thrust pads for the PL-41 for $25/plus shipping. I'm thinking stainless may be problematic if the bearing well were allowed to run dry. The end of the spindle would be shot. Also, I don't think stainless would be as quiet - but what the hell do I know?
I don't like the idea of metal at all. The Delrin is closer to the original.
If this applies to the PL55D as well, I'm in . . . otherwise a great thread! I may have to look for a 41 meself!!
I don't have a clue. Open it up and take a look. It's really very easy. Believe me, I'm not underestimating the ease at opening up the spindle housing (on the PL-41 anyway). It's about as easy as screwing the cap off a bottle of beer.
Well look what showed up at my house today.:scratch2:
Not our donor unit - the arm on this one is fine. But another dustcover falls victim to a shoddy shipper (can't blame the carrier on this one - it was the packing). Cracked at the right rear hinge. Pretty dirty. Looks like it spent some time in a barn.
Damn Rob. You're stacking 'em like cord wood. Trying to corner the market, eh?
I'm sure it'll revert completely to his tonearm pursuit and other mods once this diversion is over (Monday). He's also in on this thrust bearing deal.
Heck yeah - I consider this a place for all PL-41 lovers to put in their 2 cents on the possibilites for this humble yet wonderful table.
Plus, I have no idea how long it's gonna take for me to settle on an arm so I've invoked the "Talk amongst yourselves" clause.
Still looking for ideas on invisible plinth mods. I was pondering adding some extra wood inside the base, or maybe some vibration deadening material. Any thoughts on feet?
