Mark Levinson ML-9, how to open up the front
simbatran
I have this amp, built like a tank, so powerful and so sweet that I love to keep it clean until the day it (or me) goes down.
I am able to open the sides, but I cannot seem to be able to open the front to clean up the power button and tighten it up, it is a bit loose.
Thank you.
There are 4 screws on the inside that hold it in. I think they hold the handles on and and socket caps if I recall correctly.
I opened the top and found it very hard to unscrew anything from the top, because the 3 huge capacitors are on the way. I am trying to open the entire front and lie it down, just like the sides. It would be much easier if the front can be opened and lie down.
If you unscrew the side heatsinks its easier to get to the bottom front panel screws. They won't come completely away because of the wires, but there should be enough slack to get an easier angle at the front.
