tomlinmgt
Lunatic Member
That's a pretty bold statement....I know. And, honestly, maybe a little far reaching and not entirely accurate. But let me make my case.
I picked up JBL L250's back at the end of last summer and have been trying to get these things to play in the same league as my Infintiy QLS-1s, Altec 19's, Magnepan MG-IIIa's and Acoustat Spectra 22's ever since. In spite of trying several different combinations of amps, preamps and DACs the JBL's just haven't been able to stay in the ring with any of the aforementioned. I've continued to work with them, trying a little tweak here and there by changing cables, the placement of the speakers and acoustic treatment devices but nothing has "flipped the switch", as I like to call it...you know, the one that makes you forget everything except how insanely good everything sounds and compels you to sit for hours on end in wonder and admiration, neglecting priorities and avoiding responsibility with the dedication of a teenager. The 250's have done just about everything almost good enough to get there, but just haven't been able to cross that threshold.
Until last night.
The biggest issue I've had with the JBL's has been with their somewhat sloppy reproduction of LF. It's played hell with their PRAT and melodic accuracy in the mid and upper bass regions. When those things are monkeyed up it seems most every other component of fidelity suffers as well. So severe were their transgressions I was actually losing enthusiasm for my audio hobby. I no longer found myself wanting to listen to music like I normally do and was spending a lot less time doing it. But last night I happened to be messing around behind one of the speakers while playing some Tool (Lateralus, in case you're wondering) and heard the most gawdawful bass sounds coming from the port. It was like I'd stepped in a pile of dogshit...just simply unmistakably offensive. So I grabed a handful of old socks and loosely stuffed both ports and "CLICK!" went the switch.
With that "correction" of LF reproduction everything
took a decidedly forward step in performance. Tonality, balance, resolution, scale, etc.....I mean the whole friggin' enchilada....was improved sufficiently enough that the JBL L250's now hold court with some of the finest speakers I've had the pleasure of owning/listening to. It's not the first time correcting LF has had this effect for me. When I implemented my distributed bass rig and got it dialed in the same thing happened. The big Infinities, the iconic Altecs...all of those great speakers took a definite step forward in performance when LF reproduction was optimized. Of course, the key with DB is not only making sure the system itself is right but that the mains are right as well. As wonderful as DB is it won't correct/mask LF issues with the mains and that was clearly demonstrated with the 250's. But isn't it profound how a proper LF foundation bolsters the performance of everything that's happening above it? I've been able to enjoy speakers that maybe miss the mark a little bit on top and have even found speakers that don't quite nail the mid range to be quite a fun listen...but in all those instances the common denominator that made them a fun listen was solid LF reproduction.
To me this illuminates the absolute importance of getting LF reproduction right before all else....be it through speaker placement, DRC devices, acoustic treatments, supplemental bass systems or a combination of any or all....as when it's wrong it has a unique ability to behave like a stumbling drunkard that's entered the room, creating distraction and disruption that's impossible to ignore or get used to.
So now, for the first time in about six months, I'm really looking forward to getting home tonight to listen to some music.
Until last night.
