basicblues
Well-Known Member
I aquired a Pioneer SX-5590 (SX-1250) a couple of years ago. I had so many projects at the time I decided to set it aside until I could devote the necessary time to restore and repair. So in the meantime I rounded up a switch I needed (thanks Echowars) and a couple of missing knobs.
This one is a beautiful clean unit that I hope will have a place of prominence among my other monsters. Over the last couple of weeks, I've mainly just been detailing the unit and refinishing the wood & metal parts (no not the faceplate too).
Close inspection reveals the unit is likely to be all original inside. I knew when I got the unit that it might have a few (hopefully) minor issues. When the unit was intially powered on, the relay clicked and produced sound on both channels. Then the sound disappeared, then right back on again a few seconds later. The unit was disassemabled as necessary to allow full access and proper cleaning of the controls & switches which is just about an all day deal. Finally, and slowly the unit was back together enough to start testing. The second power up: still have sound in both channels, still intermittent with popping in the right channel. Inbetween relay clicks, I saw a good "flash" inside the relay. The unit still works but now the relay takes longer to engage and I have popping along with sound in both channels.
Since I haven't been able to stablize the unit enough to test and before taking the next step to clean and burnish the relay. Is there anything else I might need to check first?
On the indicator lamps: The A/B/C speaker indicators & the function indicators (AM/FM/etc) blink on and off. When the unit is first powered on, the selected indicator lamps work as they should, then blink off for several seconds, then back on again, then repeats with time on/off varying. All of these lamps as well as the panel lamps work and doesn't seem to have any connection to other issue as described above.
