Wigwam Jones
Caesar non supra grammati
I have a pair of The Fisher XP56b speakers. I'd like to 'modernize' them, but I haven't yet decided how to do that.
The cabs are in excellent condition. Good wood veneer, wouldn't need much more than a nice refurb, no need to even strip/refinish; probably just some steel wool and minwax.
The cabs measure 21" tall x 11.5" wide x 9" deep. The cabs appear to be constructed of 1/2" MDF; the back is flush-mounted and the front is mounted in about 1/2". The speaker board appears to be 1" thick.
The speakers are a sealed two-way design. 8" woofer, rubber surrounds which appear to be in excellent condition. Cone moves freely, no rubbing, sound fine. The mid/tweet appears to be about 4", paper cone, has some mild rippling distortion to the paper cone, as if it had gotten wet at one point. Pulled the tweeter, no sign of any damage, though. Manufacturer code on the magnet of the tweeter is 137 / something (can't read). The cab appears to be stuffed with fiberglass. I haven't pulled it out, nor have I pulled the woofers yet to see what lurks beneath.
My first thought was to simply check out the crossover and see if a cheap recap might not do wonders for this little set of speakers. If that doesn't bring them into shape, then perhaps replace the tweets.
However, that brought me to trying to figure out the volume of the cabs. I tried, I really did. But I keep coming up with silly numbers for the volume, like 1.25 cubic feet / 25 liters. That can't be right, can it?
So, first things first; can someone tell me what the volume of these cabs happens to be?
Second, what are your thoughts on simply recapping these?
Third, if you were going to replace the tweets, what would you be looking at in the way of low-buck replacements? Would you replace just the tweets, or go for the full monte and do the woofers too? Remember these are sealed cabs, not vented. I'm looking to keep them that way - high efficiency - want to use them with my new Squidward-built tube amp.
Any and all suggestions welcome, including 'throw them in the trash and start over'! Although that would be less fun.
