edd9000
Don't Panic!
Thread buffer rcm in the works.
This is my keith monks/loricraft style rcm in progress.
I used a piece of acrylic for the platter, the 3 holes were so i could hold it in the lathe.
This is the motor assembly, its an 80rpm gear motor from a surplus website, all of $7.50
Main spindle in bearing
The arm wont sit quite this high, i havnt cut the hole in the top for it yet. there are 2 bearings in its holder, and 2 small beaing on the arm shaft.
This is the vacuum nozzle that will be attached to the arm, the white piece pushes into the metal tube. It is teflon.
Im yet to sort out the vacuum pump, but i have a couple laying around. The drive for the arm will be sorted when i have the vacuum working, probably rc servos (lift and rotation) powered by an arduino.
edd
edd
