Hello everyone! My Pioneer SX-850 is no longer getting the relay click, but all the lights still turn on. I accidentally left it on for about a week when I moved-in to my new place and when I came back, no relay click. :tears:
I've been reading up on threads here at Audiokarma for a few days now, (thank you to everyone has contributed!) and I recommend anyone else not getting a relay click to freshen up on the thread I link to below, specifically see MarkTheFixer's 2nd post:
http://www.audiokarma.org/forums/showthread.php?t=296800
However, I'm posting here because my multi-meter readings are a little different than everything I've read in other posts. I'm hoping someone can let me know if I'm barking up the wrong tree thinking replacing my transistors on the AWR-101 board (Q5, Q6, Q7) will fix things. It sounds like it's a good idea to replace them either way.
Here are my multimeter readings from my boards:
AWR-101:
2,3: 5.5v - OK (should be 5.4v)
4,5: 13.5v - OK (should be 13.9v)
6,7: 49.5v - OK (should be 51.5v)
8,9,10: 15v - BAD (should be 36.5v) <----I didn't find a post where someone had near 15v here.
11: 11.15v - BAD (should be 28v)
13: -13v - OK (should be -13.5v)
14: -50v - OK (should be -51.5v)
15: -18v - OK (should be -19v)
*Didn't measure any other pins.
AWM-062:
11: 15v - BAD (should be 36.5v)
2: -13v - OK (should be -13.6v)
12: 8.2v AC - OK (should be 7.5v AC)
* Didn't measure any other pins.
Q5 Transistor on AWR-101:
E - 15v - BAD (not sure of the target)
B - 15.75v - BAD (someone said this should be ~32v?)
C - 19.73v (someone said this should be ~42v?)
* I don't have the exact target voltage for these on-hand, but I think what I'm getting is way off.
So the main reason I'm posting is because in all the other cases where someone had problems with AWR-101 pins 8,9,10 (and as a result 11), they usually read 0v, not 15v. I'm definitely getting 15v. Could this still be a problem with Q5 or is there something else I should be testing? I ordered new transistors because they are cheap and I'll definitely update the thread with my progress.
Thank you, I really appreciate the help!
-Matt
AWR-101:
AWM-062:
-Matt
