I have read all the threads I could find on the CTF1000. I have recapped changed all the rubber cleaned and lubed it . The deck plays fine the FF & RW work but struggle with" double LP " tapes. A regular prerecorded is about 20 minutes a side +/- these tapes RW & FF OK. So seems it can't move the extra weight from longer playing tapes . Could this be cause by the FF motor losing torque ?I thinking about cleaning the armature like on capstan motors of other decks.I'm not sure if this motor will go back together I'm trying different clutch spring settings but the clutch seems to work fine it's not cracked .I don't think the different spring settings will fix this . What do you think ?
