Yamaha P4500 amp
2tumsup
Well-Known Member
Greetings: This amp has surfaced in my area and I'm looking for some opinions on it. I've done a little research and checked out the specs on it but would like an opinion from soemone that has owned or heard one before.
I'm just thinking of using it for home use and not DJ'ing or anything like that. I have a Bryston 4B and wonder how it would compare.
Thanks in advance
I've got two, one of which I use to run my subs. I gotta think with its' rep the bryston will sound better. I'll add the P4500 fans are not the most quiet. When you're buying 400wpc+ amps though I'm thinking fan noise might not be a huge issue? Plus the Yammie has good $ per watt value.
Wish I could be of more help, I'm really just tagging up to see what others say.
Ummm, the P4500 actually puts out 720W per channel into 4 ohms. 1440w into 8 ohms in bridged mode. Dont know how you could use at home unless you wanted to destroy it or get arrested. ;)
