I picked up a used 610-ST power transformer as a replacement for a 30A project (thanks, Larry!), but unfortunately, I don't have a wiring diagram for it (and the Service Manual is no help). I know which windings are which voltage-wise (e.g. red/red/red-yellow is HV & center tap, black/black is primary, green/yellow is 6.3V heater, blue/white is 6.3V heater, blue/brown is 6.3V heater), however, I don't know which colors correspond to which windings in the circuit. Specifically, which heater secondary is isolated for use with the tube rectifier? If anyone has a 610-ST that they can peek at, or happens to know off the top of their head, I'd appreciate it.
Thank you,
-D
Thank you,
-D
