GENERAL AND TUBE INSPECTION.
1st off do a visual inspection of the top of the chassis for loose parts. Do the same underneath, looking for burnt parts, loose connections, etc. If everything looks ok, close it up. Take out the tubes, marking each one to the Tube layout plan in the manual. Very important that each tube goes back in it's original socket. Test the tubes to make sure they are ok. Pay particular attention for shorted tubes, gassy tubes, or tubes with a white getter (white getters indicate loss of vacuum and are an automatic FILE 13 candidate.) Replace any bad tubes with same tube #. You have your choice of Domestic, Europen, or Chinese(last resort in most cases). They do not have to be "FISHER" branded although all FISHER branded tubes will usually be a higher ended brand like Mullard, Telefunken, Brimar. It your wallet won't carry a big load of tubes, go used domestic or new Russian. Tubes in the Signal path (non tuner) can be rolled (swapped) to change sound quality or increase or decrease tonal effects. But mark the tubes so they go in the same socket each time.
1st POWER UP!
SPEAKERS or DUMMY LOADS (8oHm 50W resistors) are required for ANY POWER UP. Lack of a load on the output transformers can/will burn out the transformers, and cause other damage to the output tubes, and associated circuitry.
Don't Plug it in to a wall socket and just turn it on. Get a variac, and bring up the voltage in stages, checking for smoking parts, dead tubes, etc. Start at 40V and leave it for an hour like that. What you are doing is "reforming the capacitors" so they can at least work during testing. Raise the voltage after an hour by 10 volts, doing this until you get to 100V. After 100V @ 1 hour without problems go ahead and plug in to wall socket. Watch for tubes "redplating", can capacitors getting hot, or warmer than radiant heating from the transformers, smoking resistors, etc. If you see any of this at any time, shut it down NOW! Then fix the problem.
Read any and all threads on the 500-B or 800-B in this and the TUBE Forum. Lot's of good information. The 500-B/800-B are the same except the 800-B has an AM tuner in it that the 500-B doesn't.
Ask questions if u run into problems.
Larry
